Finishing with Rit dye
Forum topic by dpwalker posted 12-22-2010 11:22 PM 4970 views 0 times favorited 5 replies Add to Favorites Watch
View dpwalker's profile
dpwalker
273 posts in 2796 days
12-22-2010 11:22 PM
Has anyone had any experience with inlays dyed with Rit fabric dye? I want to inlay veneer I dyed red with Rit into Curly Maple. Specifically I am worried about the dye bleeding into the Maple while I try to finish the piece. Any info will be helpful.
-- You have not really lived until you do something for someone who can never repay you.
5 replies so far
View hObOmOnk's profile
hObOmOnk
1381 posts in 4092 days
#1 posted 12-23-2010 12:54 AM
This is a frequently reoccurring topic.
Fabric dyes and food colorings are generally not color fast when used to dye wood.
Best to use dyes designed for wood, e.g. TransTint.
I’m speaking from experience. I’m a chemist and I teach wood finishing.
-- 温故知新
View fussy's profile
fussy
980 posts in 3015 days
#2 posted 12-24-2010 09:44 AM
On the other hand, I’ve heard it works well, with a few caveats. Hobo is right about colorfastness, but unless it’s going to be in direct sun, it will be ok. There’s a multitude of colors possible, and you can’t argue with the cost. The other things to consider are; grain raising—raise it and sand it down beforew you dye, and don’t use water-based finishes, unless you first seal with shellac.
Steve
View Vern Little's profile
Vern Little
103 posts in 3502 days
#3 posted 12-25-2010 04:46 PM
You might try dissolving the Dye in alcohol. Just a thought. As Steve said you can’t beat the cost.
-- Earth first, we'll drill the rest of the planets later. Vern
View knotscott's profile
knotscott
7980 posts in 3340 days
#4 posted 12-25-2010 04:47 PM
I asked the same question last summer before using the RIT dye on a guitar. The user comments were that they hadn’t noticed fading yet. I imagine it’s not a good choice for frequent exposure to direct sunlight. We’ve only had it on the guitar for a few months now, but there’s no sign of fading. I did coat it with spar varnish with UV blockers to help prevent fading. I have no doubt that a Transtint dye would be a better choice, but using those would have meant a 30 mile trip and a $45 expenditure vs 3 miles and $6, so I gave the RIT dye a try and was pleased with the initial results. Time will tell about fading.
View shipwright's profile
shipwright
7966 posts in 2763 days
#5 posted 12-25-2010 06:23 PM
Why take the chance on something you’ve put a lot of work into? You can buy a 12 bottle set of aniline dyes for $48 and each bottle will give you a pint of dye. Is that too expensive? http://www.woodessence.com/ColorFX-Dye-Trial-12-Color-Kits-P51C12.aspx This is a “starter set” but it is a lot of dye and you can always pick up larger amounts of the colors you use most when you need them.
