First Commission!
Forum topic by Dustin posted 07-09-2017 06:42 PM 845 views 0 times favorited 23 replies Add to Favorites Watch
View Dustin's profile
Dustin
595 posts in 940 days
07-09-2017 06:42 PM
Topic tags/keywords: question cherry cabinet
So, after donating that candle stand I made to my church to use as a communion table, they asked about building them a welcome desk to replace their current one. I submitted the following sketchup design as a proof of concept:
Again, this was proof of concept only (and I’m new to Sketchup in general), so that’s why there are gaps near the adjoining faceframes.
Anyhow, I’m building the unit as three separate cabinets to be assembled on site, and the top will be 3/4 – 7/8” (depending on the rough stock) solid cherry. My question is this: what’s the best way to attach the top? My thoughts were to build it in three pieces, like the cabinets, then bring it flush during assembly, attaching it with screws from the underside of the cabinets. Should I bother trying to mechanically fasten the top sections together? It wouldn’t be better to build the top as one piece, would it?
Any suggestions are greatly appreciated!
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
23 replies so far
View BlasterStumps's profile
BlasterStumps
979 posts in 639 days
#1 posted 07-09-2017 06:47 PM
I’m thinking that if you don’t have a one-piece top, don’t try to make the cabinets too close fitting together. Kind of like you would have with a sectional office desk.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View JAAune's profile
JAAune
1853 posts in 2516 days
#2 posted 07-09-2017 06:56 PM
A one-piece top will result in weak corners at the rear where there’s some short grain. But assembling three sections will require some very wide miter joints that are prone to opening up over time. Wide miters in solid wood are always a potential issue if the humidity changes. So I’d agree with Blaster that separate tops should not be fastened together but should be allowed to have a gap instead.
If you do a single, solid cherry top like that, firmly screw it on one side (perhaps the front edge of the middle cabinet) and use slotted screw holes everywhere else to attach it to the base to allow for expansion and contraction.
Personally, I’d use veneer with solid wood edging to build that top since it would have a cleaner appearance and be far more stable.
View Aj2's profile
Aj2
1872 posts in 1997 days
#3 posted 07-09-2017 07:22 PM
I second separate tops.I also think you should consider Cherry plywood with a solid wood edge.I don’t like plywood but it just seems right for some reason.
-- Aj
View jonah's profile
jonah
1917 posts in 3498 days
#4 posted 07-09-2017 08:06 PM
I’ll second (third?) the suggestion to use hardwood veneered plywood for the top. Use solid wood edging and sand carefully, but it’ll be way, way more stable that way. Be sure to put a skookum finish on it, since it’ll likely be used pretty hard.
View CharlesA's profile
CharlesA
3351 posts in 1997 days
#5 posted 07-09-2017 08:13 PM
Menards has cherry plywood (some in store/some ship to store) in 4×8 sheets. Hood Distribution on Hurstbourne carries some pretty high grade cherry plywood in 4×8 sheets with a $100 minimum order for retail. I think you give them a 24 hour notice and they’ll pull it for you. That’s if you don’t want to glue your own veneer.
Dustin
#6 posted 07-09-2017 09:36 PM
Thanks for all the suggestions, folks. I had considered the veneer route, and building as one large plywood top, but that raised the question of where to get plywood large enough (it’s almost 105” wide at its widest point). For that matter, even handling something that size seems like a logistical nightmare as I’m a one man operation in a fairly small garage (it’s a 2-car, but under the bedrooms of the house, so there’s a rather obnoxious support pole right in the center of it). Feel free to correct me, though, if I’m looking at this the wrong way.
Aj/Blaster, I hadn’t considered a gap, mainly because I was thinking movement wouldn’t be much of a factor here (grain will be ran parallel to the front edge of each piece, and longitudinal movement is supposed to be almost non-existent), but after looking at some sectionals, I think I see what you’re suggesting. Getting them all perfectly flush seems like a right pain anyhow, so what about slightly rounding over or chamfering the edges that butt up against each other? Is this what you’re getting at?
jonah
#7 posted 07-10-2017 12:06 AM
If you decide to go three separate pieces, make sure there’s enough of a gap so it looks intentional. If not, it’ll just look like a mistake.
BlasterStumps
#8 posted 07-10-2017 12:44 AM
...slightly rounding over or chamfering the edges that butt up against each other? Is this what you re getting at?
Yes, that is what I was thinking.
Mike
- Dustin
View TungOil's profile
TungOil
1058 posts in 694 days
#9 posted 07-10-2017 02:28 AM
I would also suggest making the top from a single piece of plywood, edge banded in some way. Much more stable and a single top will look better. Imagine if your kitchen had individual tops over every cabinet?
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
Dustin
#10 posted 07-10-2017 12:14 PM
- TungOil
I agree, but again, this is something I’m failing to overcome logistically, as it’s too wide for a standard 4×8 sheet of plywood to cover the top. If they wanted it a little smaller, I’d be all over this.
Mike
- Dustin
- BlasterStumps
Thought so, Mike, thanks for clarifying!
View gargey's profile
gargey
1013 posts in 975 days
#11 posted 07-10-2017 12:39 PM
Do separate tops and then paper mache between them when you install.
jonah
#12 posted 07-10-2017 01:12 PM
Some suppliers will stock 4×10 foot sheets of plywood, but not likely cherry veneered stuff.
View Just_Iain's profile
Just_Iain
291 posts in 615 days
#13 posted 07-10-2017 01:34 PM
What if you split a plywood top by adding a very simple ‘cross’ in the centre of the top? It would have to be 9” wide (105” – 96” = 9”).
Or go with a contrasting 4” trim around the edge? On the diagonal you would be able to make the 96” plywood work.
-- For those about to die, remember your bicycle helmet!
View LittleShaver's profile
LittleShaver
420 posts in 819 days
#14 posted 07-10-2017 01:50 PM
I like the 4” edge banding, but I’d use solid cherry to match the plywood. Edges take the most abuse and would allow the use of the veneer with less risk of damage.
-- Sawdust Maker
Dustin
#15 posted 07-10-2017 02:11 PM
What if you split a plywood top by adding a very simple cross in the centre of the top? It would have to be 9” wide (105” – 96” = 9”).
- Just_Iain
I was actually thinking about this a little this morning. Considering how wide the middle unit is, using a “strap” of plywood running front to back in the middle, then just splitting a standard piece and securing all well. I would think this would be sturdy.
However, if going that route, I’d rather do a thick-ish veneer of cherry over the top as opposed to cherry plywood, maybe 1/16-3/32”? Running parallel to the front of the middle section all the way through, and mitering the corners of the vener to fit the edge.
Thoughts from you folks with veneer experience: would this thickness cause excessive wood movement and eventual separation where the veneers join on their edges, or would thin stock be sufficiently “wrangled” by the glue?
