Jointer and Planer Suggestions Needed
Forum topic by clschaffer posted 07-09-2017 11:52 AM 1244 views 0 times favorited 17 replies Add to Favorites Watch
View clschaffer's profile
clschaffer
8 posts in 443 days
07-09-2017 11:52 AM
I’ve found myself at a loss. I’m looking to add a jointer and a planer to my shop. I found a Rikon 25-210 jointer/planer combo on Craigslist for $1,000, but I hear negative reports regarding the outfeed bed. Negative reports I’ve heard is that you’ll need to adjust it fairly often depending how ofter you change from jointer to planer. I guess it starts to tilt towards the blades. It’s a good looking machine, I love the footprint as far as not taking up much shop space, but I don’t know if it’d end up being a headache.
Next option is to purchase a jointer and a planer. I’ve been looking at the Ridgid JPO610 and seems to have very favorable reviews. I can pick it up on Craigslist anywhere from $350-$450. Regarding the planer I’ve had a few people recommend I get a Triton TPT125 from Rockler. I don’t know anything about the planer, and can’t seem to find much for reviews. YouTube has some, but they’re not really detailed. Planer sells at Rockler for $349.99. Please let me know your experiences with the Triton, or a friends experience.
My budget has me at $1,000, so I’m there regardless which direction I go. I’ve looked at Grizzly’s website and they have a Jointer/Planer 10” combo machine that appears nice, but I’m not sure what to think about the outfeed table issue. Please throw me some advice, thoughts and/or suggestions.
Thank You in Advance!!!
17 replies so far
View EarlS's profile
EarlS
1132 posts in 2376 days
#1 posted 07-09-2017 12:50 PM
Is there a reason you want a combination jointer/planer? The DeWalt 735X planer is ~$600 or less, and a decent Grizzley jointer can be had for about the same amount.
clschaffer
8 posts in 443 days
#2 posted 07-09-2017 12:56 PM
- EarlS
I’m open to just about anything. I’ve been drawn into the combo units simply for the footprint. 1 machine vs. 2 gives me a little more room. I know it’s not a big difference.
View Logan Windram's profile
Logan Windram
346 posts in 2490 days
#3 posted 07-09-2017 01:08 PM
If you’re a one man shop and you are pretty good about organizing your milling, the combo machine makes a lot of sense. The only reservation for the combo is if your machine is down, your jointer and planer are down.
It’s been said so many times but it’s worth repeating…. get an 8 inch jointer or wider if possible. if your budget brings in a 6 inch don’t fret, jointer is better than no jointer…. but having that few extra inches is nice especially with plain sawn stock which tend to come in wider dimensions.
My current set-up is a rigid jointer and grizzly benchtop planer… I can still get fabulous results, so it important to realize that while machine quality is important, tuning the machine, having sharp blades and technique are almost as important. I am building a 900 sq ft garage this fall, so early next year probably going to do a spiral combo machine… but start slowly, don’t dump a ton of money into this if you don’t have to.
Logan Windram
#4 posted 07-09-2017 01:12 PM
- EarlS
My shop is small in my basement, I can only joint, plane stock that is 60” of less, and need about 10 feet of space on both sides of the machine…. that’s a spade eater, the combo would save a tone of space for me.
I m open to just about anything. I ve been drawn into the combo units simply for the footprint. 1 machine vs. 2 gives me a little more room. I know it s not a big difference.
- clschaffer
clschaffer
8 posts in 443 days
#5 posted 07-09-2017 02:40 PM
If you re a one man shop and you are pretty good about organizing your milling, the combo machine makes a lot of sense. The only reservation for the combo is if your machine is down, your jointer and planer are down.
It s been said so many times but it s worth repeating…. get an 8 inch jointer or wider if possible. if your budget brings in a 6 inch don t fret, jointer is better than no jointer…. but having that few extra inches is nice especially with plain sawn stock which tend to come in wider dimensions.
My current set-up is a rigid jointer and grizzly benchtop planer… I can still get fabulous results, so it important to realize that while machine quality is important, tuning the machine, having sharp blades and technique are almost as important. I am building a 900 sq ft garage this fall, so early next year probably going to do a spiral combo machine… but start slowly, don t dump a ton of money into this if you don t have to.
- Logan Windram
Great Advice!!! Thank You I appreciate it.
View PaulHWood's profile
PaulHWood
436 posts in 2281 days
#6 posted 07-09-2017 03:12 PM
I have the ridgid and like it, but got it for $225 new (HD close out) It was $449 full retail. I would shoot for $200. I have seen the Grizzly used in very good shape in that range too.
I picked up a dewalt 733 (earlier version of 734) and it works quite well. I have missed out on some $300 735’s on craigslist.
I would say with a $1000, you could buy the grizzly new and the 735 new. You could also likely find both used for closer to $500
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
View ArtMann's profile
ArtMann
952 posts in 844 days
#7 posted 07-09-2017 03:15 PM
I have a Jet JJP-12HH combo machine now but I used the Ridgid jointer and TP1300 lunchbox planer for many years and I had no complaints. In some ways, I liked the lunchbox planer better than the heavier iron that I am using today. I wish I hadn’t sold it. I changed directions with my woodworking about 3 years ago and needed a 12 inch jointer. The Jet has been very good and I would recommend it but with a few caveats. It is pretty far past your current budget though.
clschaffer
8 posts in 443 days
#8 posted 07-09-2017 03:18 PM
I picked up a dewalt 733 (earlier version of 734) and it works quite well. I have missed out on some $300 735 s on craigslist.
- PaulHWood
Shoot that was a great price on the Rigid new. Currently HD is selling them for $599. I hear a lot of good about the 735. The negatives I hear regarding it is it eats blades quick and snipe is an issue. I understand snipe is what it is and there’s only so much you can do. I’ve heard of a few tricks that seem to minimize it considerably if not completely. I currently own a Grizzly table saw and absolutely love it, so I’ll definitely look into getting a Grizzly jointer.
clschaffer
8 posts in 443 days
#9 posted 07-09-2017 03:21 PM
I have a Jet JJP-12HH combo machine now but I used the Ridgid jointer and TP1300 lunchbox planer for many years and I had no complaints. In some ways, I liked the lunchbox planer better than the heavier iron that I am using today. I wish I hadn t sold it. I changed directions with my woodworking about 3 years ago and needed a 12 inch jointer. The Jet has been very good and I would recommend it but with a few caveats. It is pretty far past your current budget though.
- ArtMann
Yes Sir it is. I’ve actually drooled over the JJP-12HH. A buddy of mine knows a guy that has one. He’s the one who got me thinking about an all in one. The Rikon 25-210 I’m keeping an eye on is intriguing, but I can’t seem to find any reviews on it. Reviews for the 25-210H is positive. Same machine just has the helical cutters.
View MrUnix's profile
MrUnix
6768 posts in 2227 days
#10 posted 07-09-2017 03:31 PM
Since you are considering a CL find, keep an eye out for a Makita 2030 or Hitachi F1000A combo unit… built like tanks, easiest knife changes of any machine on the planet, and no swap-over time needed to go from jointer to planer.
View Sparks500's profile
Sparks500
184 posts in 358 days
#11 posted 07-09-2017 03:33 PM
It has been my experience, and I have no experience with these particular jointer planers, that machines that do multiple things never do them as well as dedicated machines. I tried a shop smith, and after a month I couldn’t wait to get rid of it.
I have a 12” lunch box planer from Wood River with helix cutterhead that I got on closeout at Woodcraft and a Jet 6” jointer and manage just fine. If you look around on Craigslist, Offerup, or Letgo, you can find some pretty good buys on 8” jointers.
Im thinking about the Woodgears Jointer project, in that its a 12” Jointer that has a footprint comparable to an 8” jointer.
-- A good day is any day that you're alive....
View Loren's profile
10476 posts in 3676 days
#12 posted 07-09-2017 03:36 PM
I have had some combos and like them. Sure,
they are a hassle sometimes, but almost everything
in woodworking is a hassle sometimes.
View JRsgarage's profile
JRsgarage
253 posts in 537 days
#13 posted 07-09-2017 03:52 PM
i was looking into the combo units for a short while and iirc, the adjustability of the tables were a concern on some
  • i see a inca combo unit with motor on side, locally for $500
-- Two is One, One is None
Sparks500
#14 posted 07-09-2017 04:00 PM
I have an inca 560 sitting in my garage. I got it off OfferUp from a guy whose father in law gave to him. I paid $100 for it on the condition he’d get another 100 when he found the outfeed table. 4 months later he can’t find it under his father in laws mountains of crap. Works great as a planer, motor runs great, but I’m probably going to wind up parting it out.
I haven’t had great experiences with combo machines
View bret0826's profile
bret0826
6 posts in 343 days
#15 posted 07-16-2017 11:40 PM
I would get two machines and look real close at grizzly.they are outstanding machines for the money
