New Table Saw Blade
Forum topic by mangorockfish posted 07-08-2017 09:07 PM 1349 views 0 times favorited 25 replies Add to Favorites Watch
View mangorockfish's profile
mangorockfish
18 posts in 585 days
07-08-2017 09:07 PM
Been asking around about how to really tell if my table saw’s blades are dull. Have decided to replace the blades on both saws. One of the saws is a 113 series 10” Craftsman and the other is the 315 series. One is at my regular house and the other is at the vacation house, so probably will get two of the same. Most of what I’ll be doing is ripping as I cross-cut with my miter saw and radial arm saw. So now, what kind of blades do I need, brand, tooth count, where to buy, etc.? What about a good radial arm saw blade to do everything for a 10” Craftsman also? Thanks
25 replies so far
View ArtMann's profile
ArtMann
1215 posts in 1050 days
#1 posted 07-09-2017 01:10 AM
I don’t have a catalog in front of me so I can’t give you a model number but I like the 30 tooth Glue Line Rip blade made by Freud. It is the one with the red non-stick coating. In your case, I would strongly recommend the narrow kerf version. I used a Craftsman 113 series table saw for about 20 years and when I replaced the regular blade with a thin kerf one, it was like I replaced the motor with a higher power one.
I used to have a Craftsman radial arm saw. It had this tendency to self feed to the point it would stall itself out. I sold it rather than deal with the problem but I hear the crosscut blades with a negative hook angle work much better.
View Madmark2's profile
Madmark2
408 posts in 822 days
#2 posted 07-09-2017 03:01 AM
Freud LU83R010 great combo blade and glintingly sharp.
M
View Woodknack's profile
Woodknack
12455 posts in 2614 days
#3 posted 07-09-2017 05:04 AM
Generally if you are in doubt that your blades are sharp, there is no doubt, they are dull. (although sometimes you can get more time with a good cleaning)
View Rich's profile
Rich
3979 posts in 823 days
#4 posted 07-09-2017 05:25 AM
- Rick M
Rick’s right about the cleaning. Get a cleaning solution (I use CMT Formula 2050, but there are other good ones as well), and follow the instructions. It’ll make a big difference.
View MrRon's profile
MrRon
5258 posts in 3477 days
#5 posted 07-09-2017 03:51 PM
I find when the blade starts to bog down, that indicates the blade is no longer sharp. This takes into account the blade is clean and not gummed up. A clean, sharp blade will crosscut without leaving raised splinters at the bottom of the cut.
View Planeman40's profile
Planeman40
1330 posts in 2995 days
#6 posted 07-10-2017 02:47 PM
I’m going to be burned at the stake for saying this, but the BEST circular saw blade I have ever had over the past 55 years of using a table saw is the one I bought at Harbor Freight. This is it: https://www.harborfreight.com/12-in-96t-finishing-circular-saw-blade-62730.html
It is used on my $4,000 Austrian-made Hammer 48” x 48” sliding table saw (12” blade size). I had Forrest Blades special punch the arbor hole to fit). There is a 10” blade available. Its a long story how I came to use this blade, but this is for another time.
Planeman
View dday's profile
dday
168 posts in 1663 days
#7 posted 07-10-2017 04:43 PM
I agree with the HF blade suggestion. As a hobbyiest wood worker, it seems more efficient to me to replace a blade that’s dull ( after a few cleanings ) than to try and sharpen it myself or send it off to be sharpened and possible pay more that it’s worth to do so ( with shipping and cost). These are very servicable blades and very reasonably priced. If you buy them one at a time, you can get 20% off on top of the great price.
Woodknack
#8 posted 07-10-2017 05:00 PM
Planeman, what makes it the best?
View ocean's profile
ocean
138 posts in 1067 days
#9 posted 07-10-2017 05:16 PM
I have a 113 craftsman also and my one blade I use most of the time is a thin kerf 10” 60 tooth ATG for fine cuts in solid wood and ply. It has a good life span and is a reasonable cost ($36). Go with less teeth for construction grade lumber. You can find it at HD.
-- Bob, FL Keys
View builtinbkyn's profile
builtinbkyn
2677 posts in 1174 days
#10 posted 07-10-2017 07:48 PM
I found an article on cleaning blades a few weeks ago. I think it was one of the magazines – FWW or PWW – don’t remember which, but they did a test on cleaning solutions “designed” for cleaning blades and then some household products they felt would do the job. The designated blade cleaning solutions did their job as expected, but Simple Green and laundry detergent did the job equally well.
I have a bunch of blades that need to go to a sharpening service. There’s one not too far from my house which charges $15/blade which will make it worthwhile for me to do. Now I just have to do it.
OP give your blades a good cleaning and then maybe look in your area for a sharpening service. Also, I used to use Freud blades almost exclusively, mixed in with some CMT, but after picking up a Forrest WW II blade, I think that’s where my money is going. They’re located in New Jersey and not too far for me to drive to drop off blades for reconditioning. They’ll replace chipped/missing teeth and sharpen, all for a reasonable price, considering replacement is much more expensive.
-- Bill, Yo!......in Brooklyn & Steel City :)
View jonah's profile
jonah
1966 posts in 3532 days
#11 posted 07-10-2017 08:18 PM
I don’t see the appeal of throwing away a perfectly good saw blade rather than paying $15 to sharpen it. Local places charge about that, and if you find a good one, you don’t need to mail it anywhere.
View Nubsnstubs's profile
Nubsnstubs
1433 posts in 1964 days
#12 posted 07-10-2017 10:13 PM
Been asking around about how to really tell if my table saw s blades are dull.
Have decided to replace the blades on both saws. One of the saws is a 113 series 10” Craftsman and the other is the 315 series. One is at my regular house and the other is at the vacation house, so probably will get two of the same. Most of what I ll be doing is ripping as I cross-cut with my miter saw and radial arm saw. So now, what kind of blades do I need, brand, tooth count, where to buy, etc.? What about a good radial arm saw blade to do everything for a 10” Craftsman also? Thanks
- mangorockfish
If it’s carbide, look at the edges of the teeth. If you can see a line, the blade is dull. If lines are not visible, it’s most likely still sharp. Another way to tell if it’s sharp, rake a tooth on a finger/thumb nail. If it raises a burr, you blade is sharp. If not, it won’t do anything. Now that is said, make sure the blade is in your hand and not still on the arbor.
Above is for carbide only. Steel is another story. I don’t have any words of wisdom on steel blades as I never used any in my 40+ years as a cabinetmaker/wouldworker. .......... Jerry (in Tucson)
View Nezzerscape's profile
Nezzerscape
30 posts in 1097 days
#13 posted 07-11-2017 05:32 PM
I use to love Freud, but after using Forrest blades (on both TS and radial arm saw) I would not go back. I have not tried anything from HF though.
View EricLew's profile
EricLew
228 posts in 1600 days
#14 posted 07-12-2017 05:09 AM
I have had great results with the Irwin Marples blades. Lowe’s and Amazon sell them, I have a 24 tooth rip, 50 tooth combo, and 80 tooth crosscut, and recommend all 3, they range in price from about $35 – $50 The 80 tooth makes incredibly clean cuts in plywood.
-- I love the smell of coffee in the morning, and sawdust in the afternoon
Planeman40
#15 posted 07-12-2017 03:18 PM
”Planeman, what makes it the best?”
I judge a saw blade on how it performs. With this Harbor Freight blade this is what I experienced.
1. The blade, a 12” 96-tooth carbide blade, ran dead true on the arbor and was balanced with no vibration at all.
2. The cuts were so smooth that no further finishing was needed on most cuts.
3. The carbide blade tips have stayed very sharp after 2 1/2 years use in a much used home workshop.
4. As mine is a 12 ” saw, it can cut a 2×4 lengthwise in the 4” dimention. I have done this a number of times with no problems from the blade. No heating distortion.
What more could you ask?
