nova 1624-44 switch
Forum topic by ginasdad posted 12-21-2010 05:50 PM 1159 views 0 times favorited 3 replies Add to Favorites Watch
View ginasdad's profile
ginasdad
15 posts in 3355 days
12-21-2010 05:50 PM
I have a new nova 1624-44 lathe (2 months) and am very happy with its performance. I do have two problems. When I push the start button the motor will only run while the button is depressed. I removed the switch cover and their was black wire marked ‘0’ which was not attached to a terminal. I couldn’t see a 0 wire on the switch wire diagram and couldn’t see a terminal without a wire. I don’t know if this is the problem.
The pulleys are not aligned, 2 ridges on the belt overhang the pully. I read in the manual to adjust the motor pulley. I have loosened the set screw but the pulley is firmly attached. Does anyone know an easy way to loosen the pulley? thanks
-- so much wood, so little time
3 replies so far
ginasdad
#1 posted 12-22-2010 02:25 AM
I can answer 1 of my questions today. Was able to pull the switch out of its housing and on the underside was a terminal matching the black wire. Connected it now works. Still working on the pulley problem. Suggestions appreciated. Thanks
View Vrtigo1's profile
Vrtigo1
434 posts in 2988 days
#2 posted 12-22-2010 02:49 AM
Don’t have any experience with lathes, but my first question would be have you contacted the manufacturer for help? Most reputable companies have a tech line you can call for help getting tools set up.
ginasdad
#3 posted 12-22-2010 11:17 PM
Thanks for the reply. Did the Technatool email but knew I would wait awhile for a reply. Trying to tap into the vast pool of experience which you folks have. Thanks
