Beading challenge
Forum topic by MatthewG posted 12-21-2010 05:40 AM 1033 views 0 times favorited 4 replies Add to Favorites Watch
View MatthewG's profile
MatthewG
85 posts in 2688 days
12-21-2010 05:40 AM
Topic tags/keywords: bead scraper
I have to copy an existing drawer front. It has beading (or something like it) about 1/2” from the edges—if you stand the drawer on its face, it looks like this, with three grooves and two beads on each edge.
Any advice? I tried building a matching scratch stock, but I am using butternut and it gets really fuzzy when using a scraper. The router bits I have seen are for beading the EDGE of the stock, or for creating bigger beads—these are about 7/32 center to center. I ran a “vee” bit, but the grooves are too fat—the valleys are not sharp and deep enough.
Thanks for any insight.
Matthew
-- Matthew, from beautiful Wisconsin USA
View tenontim's profile
tenontim
2131 posts in 3653 days
#1 posted 12-21-2010 05:57 AM
moulding head in your table saw.
View John Ormsby's profile
John Ormsby
1283 posts in 3646 days
#2 posted 12-21-2010 06:25 AM
You might be able to use this head with the cutter shown. It is for a tablesaw.
http://cgi.ebay.com/VINTAGE-CRAFTSMAN-RADIAL-TABLE-SAW-MOLDING-SET-SEARS-/270681368797?pt=LH_DefaultDomain_0&hash=item3f05dde8dd
-- Oldworld, Fair Oaks, Ca
John Ormsby
#3 posted 12-21-2010 06:27 AM
Here is another type for a tablesaw. It also comes with the bead knife. You will need to make sure of the dimensions.
http://cgi.ebay.com/Delta-Molding-Head-3-Cutters-Table-Saw-/170580656331?pt=LH_DefaultDomain_0&hash=item27b76640cb
You will need to make or get an insert for the tablesaw in order to be safe.
http://cgi.ebay.com/MOLDING-HEAD-TABLE-INSERT-VINTAGE-DELTA-TILT-TABLE-SAW-/370454360100?pt=LH_DefaultDomain_0&hash=item5640ccf024
MatthewG
#4 posted 12-21-2010 06:57 PM
Looks like a moulding head is the way to go—simple and easy to understand. I will see what I can find. Only gotta make 4 drawers, so a bit of messing around won’t kill me :)
Thanks, everyone!
