mortise and tenon for triangular or hexagonal tables
« back to Joinery forum
Forum topic by leftcoaster posted 07-08-2017 03:56 PM 1069 views 0 times favorited 5 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
229 posts in 991 days
07-08-2017 03:56 PM
Anyone able to provide pointers on how to lay out and cut mortises for a table whose top will not be rectilinear? How do you effectively and safely cut the tenons if the stretchers have to go on a 120 or 60 degree angle rather than a 90?
5 replies so far
View firefighterontheside's profile (online now)
18833 posts in 1971 days
#1 posted 07-08-2017 04:25 PM
If you make a hexagonal table, you can use hexagonal legs. You will be able to make mortises in the legs that are square to a face and then skipping one face of the leg, make another mortise. You aprons will all be square cut tenons.
leftcoaster
#2 posted 07-08-2017 05:18 PM
That makes sense. any tips on milling hexagonal legs?
#3 posted 07-08-2017 06:26 PM
You can do it at th tablesaw by setting your saw at 30°.
Let’s say you want 1” faces on your hexagon. Square root of 3 X 1 = 1.732…..... (square root of 3 being a constant) so this will be your stock thickness. Your stock width will be 2 or twice your face width. Now make a mark at 1/2 of 1.732 along that side. With your piece lying on the wider side, set your fence so that a 30° cut goes right thru that mark. Turn it around and cut again, flip it over and cut two more times. I had to do a bunch of research to figure this out.
https://rechneronline.de/pi/hexagon.php
leftcoaster
#4 posted 07-08-2017 06:31 PM
This is very helpful. Thank you for the clear explanation.
Let s say you want 1” faces on your hexagon. Square root of 3 X 1 = 1.732…..... (square root of 3 being a constant) so your stock width will need to be twice that. Your stock thickness will be 2 or twice your face width. Now make a mark at 1” along the 2” side. With your piece lying on the wider side, set your fence so that a 30° cut goes right thru that mark. Turn it around and cut again, flip it over and cut two more times. I had to do a bunch of research to figure this out.
- firefighterontheside
#5 posted 07-08-2017 06:37 PM
I did some math wrong. Standby. Ok, it’s fixed.
