| Forum topic by Sumdume | posted 883 days ago | 687 views | 0 times favorited | 8 replies | ![]() |
883 days ago |
Topic tags/keywords: question I am working on a snowman shaped router bowl. The bowl is 2 layers of mahagony and 1 layer of maple. I have routed the inside and need to cut the outside to the final shape. I am considering making a template and using a router to shape the outside instead of cutting it with bandsaw and sanding. I am concerned that the router will cause too much chip out. Am I fussing too much? -- Rule # 1 - Don't mix yer blood and sawdust! |
8 replies so far
#1 posted 883 days ago |
I don’t see why it wouldn’t work. Routing is used to make all sorts of shapes! -- A woman's work is never done-but power tools help! |
#2 posted 883 days ago |
Absolutely not. A router on the outside will instantly set the bowl afire and melt the router. It’s as volatile as dinamite. I lost three fingers and eleven toes trying it. That’s why they call that process the “wooden widow maker”. I think it’s banned in 53 states. -- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
#3 posted 883 days ago |
I would recommend that you use a band saw to get close to the line and finish it with a router. Taking a big bite with the router just doesn’t work well. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#4 posted 883 days ago |
Have you watched this: http://thewoodwhisperer.com/halloween-router-bowl/ -- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν |
#5 posted 883 days ago |
I’ve done it and it will work just take small bites. -- Roy L, Arizona |
#6 posted 883 days ago |
The thicher the wood the more possibilities for disaster. If you use a router “richgreer” has a good approch. I think I would cut with a bandsaw then power sand. -- Never board, always knotty, lots of growth rings |
#7 posted 883 days ago |
Thanks for the replies. I should have mentioned that I plan on using the bandsaw to get close to the line. Because I do not have a good spindle sander and my drill press doesn’t work well. I was thinking the router would leave a smoother edge and reduce the amount of sanding. -- Rule # 1 - Don't mix yer blood and sawdust! |
#8 posted 883 days ago |
As long as you get close with the bandsaw, I’d tend to agree with Rich that you should be just fine. You can always do a bit of hand sanding to fix any problem areas, but they should be pretty minor as long as you’re using the proper speed on the router, a sharp bit, and the proper feed rate and direction, especially if you’ve got the stability of a router table setup, versus trying to freehand it. -- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker." |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15783 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
