Do they still make sanding or wonder bars??
Forum topic by Dan posted 12-20-2010 11:51 PM 5148 views 0 times favorited 6 replies Add to Favorites Watch
View Dan's profile
Dan
3630 posts in 3114 days
12-20-2010 11:51 PM
I got a sanding bar from my dad that is called a Wonder Bar. I don’t know how long ago he got it but it was probably 10 years or more… The bar feels like rubber and as you sand the grit breaks away and there is new grit. The one I have is a finer grit that I use all the time to clean and polish my steel tools. Its so much better then having to deal with sheet after sheet of sand paper.
I did some searching online and cant find anything about these sanding bars. If anyone knows somewhere that still sells these please let me know. I would love to buy some more and different grits.
Thanks
-- Dan - "Collector of Hand Planes"
View Big_Eddy's profile
Big_Eddy
57 posts in 3116 days
#1 posted 12-20-2010 11:54 PM
Shopsmith dot com carries them
-- If i'd a knowed you coulda goed I'd a seen you gotta went
View DrDirt's profile
DrDirt
4526 posts in 3976 days
#2 posted 12-20-2010 11:59 PM
Like this?? on amazon
Flexible hand sanding blocks made from resilient rubber filled evenly throughout with hard abrasive grit.
Garryflex blocks are ideal for cleaning and polishing all metals and ceramics.
Use instead of emery cloth, wet and dry, wire wool etc.
Grade. Medium.
http://www.amazon.co.uk/Garryson-Garryflex-Abrasive-Block-120grit/dp/B0001P08UQ
In Auto SUpply houses they still have them…
http://www.denlorstools.com/home/dt1/page_27691/motor_guard_wb_1_block_sanding__wonder_bar_.html
View FreshPants's profile
FreshPants
10 posts in 3325 days
#3 posted 12-21-2010 04:00 AM
Sandflex handblock made by Klingspor, comes in three tasty grits.
View Dan's profile
Dan
#4 posted 12-21-2010 07:05 AM
Thanks guys!
View Gregn's profile
Gregn
1642 posts in 3217 days
#5 posted 12-21-2010 07:14 AM
Harbor Freight also sells sanding sponges.
View Toolz's profile
Toolz
1004 posts in 3976 days
#6 posted 12-21-2010 02:40 PM
http://www.cratex.com/rubindx.htm
I have been using Cratex sticks for about 20 years…they are great!
-- Larry "Work like a Captain but Play like a Pirate!"
