has anyone used poplar as a hard wood floor
Forum topic by pauljuilleret posted 07-07-2017 01:41 PM 1081 views 0 times favorited 12 replies Add to Favorites Watch
View pauljuilleret's profile
101 posts in 1583 days
07-07-2017 01:41 PM
I just finished making tung and grove siding out of poplar. after I finished the mill work I then pre conditioned it and stained it with a cherry stain, followed by two coats of spar varnish. it was then installed on a front porch. The owner now asked me about using it as flooring. I know it isn’t as hard as Oak or Maple but is harder than the southern yellow pine they have down now. toss me some ideas as to how you folks feel bout this idea. Thanks in advance for your help
12 replies so far
View gargey's profile
932 posts in 706 days
#1 posted 07-07-2017 01:46 PM
“toss me some ideas as to how you folks feel bout this idea.”
Its too soft, in addition to butt-ugly.
View ShaneA's profile
6894 posts in 2529 days
#2 posted 07-07-2017 01:52 PM
It is a bit soft, and would have to be expected to get dinged and beat up. I think it would be about expectations. Wouldn’t be my choice, not that it matters.
View johnstoneb's profile
2816 posts in 2103 days
#3 posted 07-07-2017 01:53 PM
wood database Poplar is considerably softer (560 janka), than the southern yellow pines vary from (&00 to 900) depending on species.
-- Bruce, Boise, ID
View Woodknack's profile
11293 posts in 2311 days
#4 posted 07-07-2017 01:57 PM
Poplar and SYP are going to be similar in hardness. It’s not exactly an apples to apples comparison because pine has hard/soft growth rings. I agree with Shane that it’s about expectations. It’s not going to perform or last as long as oak or hard maple but at the rate people remodel these days, maybe won’t matter.
-- Rick M,
View splintergroup's profile
1925 posts in 1153 days
#5 posted 07-07-2017 02:28 PM
Poplar is a stable wood and rather inexpensive. If the color and grain pattern are agreeable, why not use it?
It won’t have the durability of oak, but other “soft” woods get used as flooring all the time. Going in with tempered expectations might actually yield some pleasant surprises.
View MrRon's profile
4667 posts in 3174 days
#6 posted 07-09-2017 04:23 PM
All woods have been used for flooring from the earliest times. Whatever was available in the area was used. It’s only since the advent of worldwide transportation and factory made flooring that the more durable species of wood has been used. It all boils down to durability vs cost. Appearance is also another factor.
View papadan's profile
3584 posts in 3299 days
#7 posted 07-09-2017 04:27 PM
Use it but apply an epoxy finish to harden the surface.
View tomsteve's profile
764 posts in 1150 days
#8 posted 07-09-2017 04:43 PM
- MrRon
quite a few years ago i was over a friends helping him with some kitchen plumbing in the oooooold farmhouse he was living in. the house has wide plank shiplap flooring that i thought was different shades of stain on different boards.workin down in the basement/root cellar i stopped and looked at the underside of the flooring. there was red and white oak, maple,poplar, pine, hickory. it wasnt different shades of stain- just different species of lumber- whatever was available on the property to cut.
what blew me away was a couple months later helping him with some siding. we tore off the old shiplap siding and could see the ends of the floor boards. full 2” thick!
poplar,imo, would make a good floor as long as its known it might ding and scrape easier than harder woods
View bandit571's profile
19482 posts in 2614 days
#9 posted 07-09-2017 05:08 PM
Poplar would work, then use area rugs to help protect it….like they used to do with the Front Parlors….Fancy wood around the edges where they’d show, Pine, fir poplar under a rug so it won’t show.
Maybe take so “Car Siding” and lay that down? Grooves down, of course…
View jonah's profile
1624 posts in 3229 days
#10 posted 07-09-2017 05:49 PM
With modern finishes there’s no reason you couldn’t use poplar. Look for something better than the normal big box floor poly and look at catalyzed and specialty finishes.
This stuff is amazing:
And I’ve heard good things about this:
View bondogaposis's profile
4632 posts in 2282 days
#11 posted 07-09-2017 06:34 PM
- papadan
It will still dent. I wouldn’t use it, too soft.
-- Bondo Gaposis
View Madmark2's profile
379 posts in 519 days
#12 posted 07-09-2017 06:39 PM
Ipe or jatoba come to mind – neither will easily dent.
