Drill Press Column too Short
Forum topic by HiltonHeadHacker posted 07-07-2017 01:12 PM 799 views 0 times favorited 8 replies Add to Favorites Watch
View HiltonHeadHacker's profile
HiltonHeadHacker
5 posts in 2394 days
07-07-2017 01:12 PM
Topic tags/keywords: drills drill press drill press parts
does anyone know where I might be able to get the tubing for my Grizzly Baby Drill Press. Currently the column is 15 1/4 long and I need to get it to 18” to accommodate Forstner Bits.
The outside dimension is 1 13/16 and I don’t see where the inside dimension (currently 1 21/32) or the wall thickness (currently 3/32) would necessarily need to be to spec.
I’ve called Grizzly and they don’t have a part in those dimensions. I’ve also contacted a few pipe supply houses but in looking at their dimensions on size charts I cannot find an approximation.
Any ideas.
Thanks to All,
Tony on Hilton Head.
-- Tony D
8 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3153 days
#1 posted 07-07-2017 01:31 PM
FWIW, I squeaked by with an old Delta 8” DP for ~21yr, until I finally wised up and upgraded to a larger DP. WHY? The small 8” had too few speeds (especially when using larger Forstner bits). I burnt several bits while trying to get by… quite the PITA.
IMO, bite the bullet and purchase a larger DP. Keep the 8” but buy something bigger. FWIW, I went whole hog and got the 20” floor model 12-speed. The Grizzly G7943 - 12 Speed Heavy-Duty Bench-Top Drill Press would be a good option, and that probably won’t break the bank. Just my 2-cents…
View JRsgarage's profile
JRsgarage
335 posts in 748 days
#2 posted 07-07-2017 02:13 PM
i’m not sure how well it will work but i hear some folks talk about pipes from muffler exhaust shops.
-- Two is One, One is None
HiltonHeadHacker
#3 posted 07-07-2017 02:19 PM
Mike and JR – - thanks for the quick reply. HM – - I am of the same opinion at this point. Any comments from you (or anyone else) on going for the laser pointer? Adding a laser pointer to my Miter Saw was a great improvement.
Thanks, Tony
-- Tony D
View GR8HUNTER's profile
GR8HUNTER
5381 posts in 951 days
#4 posted 07-07-2017 03:29 PM
I personally IMHO hate laser lines….... would rather punch a starter hole ...best for me :<))
View bruce317's profile
bruce317
404 posts in 1062 days
#5 posted 07-07-2017 03:44 PM
Get a steel tube turned to size at a machine shop. I would think a muffler shop tube, would be to thin of wall thickness.
Let us know how it turns out.
-- Bruce - Indiana - Sawdust is just, MAN GLITTER!
HorizontalMike
#6 posted 07-07-2017 03:46 PM
- GR8HUNTER
DITTO.
View Loren's profile
10477 posts in 3887 days
#7 posted 07-07-2017 04:41 PM
I have a laser on my drill press and I don’t
really use it. I prefer to center-punch
when I want an accurate hole. In wood
I use a brad point bit.
If you don’t mind some holes being off
by up to 1/16” a laser can be useful
for casual drilling but for precision I don’t
find it reliable. It is adjustable though, so
if I really fussed with it I suppose it
might be more spot-on.
View MrRon's profile
MrRon
5270 posts in 3482 days
#8 posted 07-08-2017 04:43 PM
The way I would do it would be to add a block to the bottom of the column rather than replace the whole column. I would do it that way because I have the machines (lathe, milling machine, etc) to machine a block bored out to accept the column and attach to the base. I don’t think wood would be strong enough to do this. Maybe you could find a pipe coupling with an inside dimension that matches the outside dimension of the column.
