Your Opinions re Variable Speed in a ROS
Forum topic by HowardInToronto posted 07-07-2017 02:42 AM 794 views 0 times favorited 21 replies Add to Favorites Watch
View HowardInToronto's profile
HowardInToronto
77 posts in 1902 days
07-07-2017 02:42 AM
My 5” Makita VS ROS just died. It slowed right down to a crawl and then smoke started coming out.
To replace it, the single-speed Makita ROS is $89. Their twin-handle VS ROS is $139 (Canadian dollars, I might add).
My question is who here has a VS ROS and how useful is the VS capability?
In the 18 years I owned it, I never changed the speed from the top setting. But I only used it on wood and MDF. I keep thinking it might come in handy on other types of materials. But the biggest issue that’s got my head turned is that the specs suggest the VS unit has significantly less vibration than their single-speed unit.
FWIW, I’m satisfied with Makita so I’m not looking at other brands.
I’d appreciate your thoughts re VS vs single-speed in a ROS.
Thanks.
Howard
21 replies so far
View TungOil's profile
TungOil
1059 posts in 695 days
#1 posted 07-07-2017 02:53 AM
ohhh, you let the smoke out. They don’t work after you let the smoke out.
both of my Bosch ROS’s are VS and I typically use them near top speed most of the time, but I do adjust the speed slightly to get the least vibration while running. The one exception was when I painted my house and had to sand the cedar siding. in that case I did slow the ROS down quite a bit.
If it were me I’d definitely go for the one that claims lower vibration. I find the vibration increases fatigue significantly.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Rich's profile
Rich
3880 posts in 790 days
#2 posted 07-07-2017 03:24 AM
+1 on TungOils preference for Bosch. They are great performers and the low vibration makes them pleasant to use.
I’m kind of a nut about ROSs since I’ve wound up buying one for each grit. I discussed it in another thread, but I like the Mirka Abranet disks, and they are expensive and I found the frequent ripping off one grit and moving to the next weakened the loop backing.
So, single speed, or VS? If I only had one, I’d definitely want VS. When getting down to the finer grits and trying to get a smooth surface without cutting through existing topcoat, I do slow it down. That’s what my Bosch is dedicated to. I don’t find it such a big deal with coarser grits, since the intent with them is to do some cutting.
5176 posts in 2694 days
#3 posted 07-07-2017 12:28 PM
I’ve used a VS Bosch for a very long time, and the only time I adjusted the speed was when it was new. I got what felt most comfortable in use and have pretty much left it there since then.
View Kazooman's profile
Kazooman
1237 posts in 2153 days
#4 posted 07-07-2017 01:16 PM
I use the variable speed function on my ros all the time. Wouldn’t buy one without it.
View splintergroup's profile
splintergroup
2429 posts in 1423 days
#5 posted 07-07-2017 02:38 PM
I never use the VS feature on both of my ROSs. That’s not saying that I may want/need it some day and if the price difference is not too excessive I can’t argue with “better to have and not need then to need and not have”
View jimintx's profile
jimintx
855 posts in 1785 days
#6 posted 07-07-2017 02:46 PM
Yes, I lean to saying get the VS. You can only know its usefulness once you have it and try it out.
I really like my Makita BO5041, and think sticking with Makita is a good plan. Mine is VS, and has a removable second grip, which i mostly never use. The $90 to $140 jump for VS seems high to me, but i haven’t shopped lately, and never in Canada.
However, I want to ask Rich, and Tungoil: which model of the Bosch ROS do you recommend? There are quite a few, and the price range is from $69 to over $200 right now.
I want to add one ROS for the purpose of keeping two grits, for convenience and saving the hook & loop surface, as Rich stated above. Maybe getting the Bosch would be nice, then I could simply look at them to know which was which, grit-wise.
Thanks all
-- Jim, Houston, TX
TungOil
#7 posted 07-07-2017 02:59 PM
Jim
I have the ROS20VS (left) and the ROS65VC. Of the two I much prefer the 65, I like that it is 2 handed and it has less vibration and ‘wobble’ than the 20. both are variable speed. I’ve had them a few years so these might not be the current model numbers but there is something close I’m sure.
The OP is happy with Makita, but I’m not familiar with their product line so I cannot comment on that other than to say that the heavier the tool, the less noticeable the vibration will be.
jimintx
#8 posted 07-07-2017 03:29 PM
Thank you TungOil. Your big one is a 6”, and is at the upper price end. I have found there is a 5”, two-handed version (3725DEVS) for about $135, vs ~ 225 for the 6” model. I am thinking of trying that one. I’d like to only have to keep one size of discs, and I have a slew of 5” already. The hole pattern seems to be a match with the ones I have.
I apologize for the derail from the straight up VS relative to non-VS topic. Thanks to Howard for starting this one. And, at least I stayed on point about variable speed ROS machines. ;=D
-- Jim, Houston, TX
View pintodeluxe's profile
pintodeluxe
5798 posts in 3014 days
#9 posted 07-07-2017 03:32 PM
All my ROS’s are variable speed. I will never go back to the single speed units.
More control = better sanding.
View bigblockyeti's profile
bigblockyeti
5285 posts in 1921 days
#10 posted 07-07-2017 03:42 PM
I have a PC 7335 which is variable speed and I have used it, but infrequently. It works best when you’re dealing with something delicate, like cedar, or when you’re perched precariously on a ladder reaching around a corner and need a reasonably aggressive paper but still need a good, slow control. BTW, this particular model has many pros and a few cons. The come being: short pad life, no pad wind up control and poor dust collection (available in a separate kit). The pros being: low profile, great power, large sanding orbit (~ 5/15”), smooth & reasonably quiet & variable speed. PC has a different looking newer model that may or may not be as good as my older one but based on B&D’s abandonment of quality for nearly all PC tools I would bet not.
#11 posted 07-07-2017 03:52 PM
Thank you TungOil. Your big one is a 6”, and is at the upper price end. I have found there is a 5”, two-handed version (3725DEVS) for about $135, vs ~ 225 for the 6” model. I am thinking of trying that one. I d like to only have to keep one size of discs, and I have a slew of 5” already. The hole pattern seems to be a match with the ones I have.
- jimintx
Jim, the 3725 (mine is just DVS) is the one I’ve used for probably 12 years or so, and it just keeps going. I haven’t even replaced the pad yet. Several years back I got to thinking how hard things would be if it dies, so i bought one to keep as a back up (PC 390). Other than trying it out, it hasn’t been used yet.
View Woodknack's profile
Woodknack
12430 posts in 2580 days
#12 posted 07-07-2017 03:55 PM
Pro variable speed.
Kazooman
#13 posted 07-07-2017 05:36 PM
Mine is a 3283 DVS that I have had for ages. It works great. One thing I like about it is that’s it has a soft rubber
“boot” that surrounds the pad close to the work. It really helps with dust collection.
One job where I use the variable speed is on the edges of end grain cutting boards. I like to give them a bull nose profile. I can S and them with the ROS if I slow it way down and keep it moving. At full speed it is too easy to create a flat spot, especialy on the corners. I can rock the sander from side to follow the profile.
TungOil
#14 posted 07-07-2017 07:58 PM
Thank you TungOil. Your big one is a 6”....
- jimintx
Nope, both have 5” pads although there is a 6” version available as well.
View papadan's profile
papadan
3584 posts in 3569 days
#15 posted 07-07-2017 08:10 PM
I have an older PC VS333 besides wood, I use it on metal quite a bit. Have never turned it down off #6. I have replaced the base plate a couple times over the years though. I hope I never let the magic blue smoke out of it! ;-)
As for your question, compare what the single speed is, compared to the VS model. Some VS tools will go significantly higher than a single speed. Faster is better when sanding.
