Festool domino
Forum topic by slowlearner posted 12-20-2010 04:32 AM 1685 views 0 times favorited 8 replies Add to Favorites Watch
View slowlearner's profile
slowlearner
8 posts in 2825 days
12-20-2010 04:32 AM
This is a cool tool but the price is a little high. Is their another tool that will do the same thing. I do think this would be nice to have just don’t have 800 plus dollars for it.
8 replies so far
View tomakazi's profile
tomakazi
686 posts in 3309 days
#1 posted 12-20-2010 04:57 AM
I cant justify the price either!!! I just set up a jig and use my router. if I had to make mortise and loose tennon joints more often, I would get one!!
-- I didn't go to college, I was too busy learning stuff - Ted Nugent
View richgreer's profile
richgreer
4541 posts in 3100 days
#2 posted 12-20-2010 05:02 AM
Take a look at the Mortise Pal. The end result, a loose tenon, is essentially the same. However, the Mortise Pal allows for more variety in sizes.
The Mortise Pal requires you to cut the mortises using a your router and bit and the Mortise Pal jig. It is a little slower and a little less convenient than the Festool domino, but it is a lot cheaper and the end result is just as good, if not better.
View Chiefk's profile
Chiefk
163 posts in 3797 days
#3 posted 12-20-2010 05:32 PM
I have a domino. It was expensive, but I believe I have gotten my money’s worth from this tool. I use it on almost every project. It is very versatile with different size cutters and matching loose tenons. pkennedy
-- P Kennedy Crossville, TN
View FredG's profile
FredG
139 posts in 3723 days
#4 posted 12-20-2010 05:45 PM
Festool too expensive ?? Check out this advertiser ;-)
-- Fred
View Loren's profile
10476 posts in 3673 days
#5 posted 12-20-2010 10:48 PM
Check out some of the higher-end dowel jigs. Trimming misaligned
parts can almost be a thing of the past with accurate doweling.
Everybody wants to obsess about joint strength – and for exterior
doors I would use nothing but mortise and tenon – but all these joint-strength
tests and one-upsmanship is a little silly for most work. Doweling,
if done right, can make stuff that’s plenty strong for most uses.
View DrDirt's profile
DrDirt
4424 posts in 3768 days
#6 posted 12-21-2010 12:06 AM
Fred – I think you have the solution… if only I still had hair…and a waistline…and a nice car…aw shucks!!
I like the woman I have just fine anyway.
I use a router and floating tennons. Michael Fortune published a great mortising jig in FWW a while back, and that is what I made. He uses 2 flute aluminium cutting end mills 3/8” so you need a special collet adaptor, or just go for the 1/4” spiral carbide.
I covet the festool Rotex 150 sander, but at 495.00 @ McFeely’s I cannot justify the price.. or 950 with the CT22 vacuum :-O !!
richgreer
#7 posted 12-21-2010 02:11 AM
Dave – I am very happy with the Rotex 125 and the Midi dust extraction unit. It’s still pricy, but quite a bit less than 950.
View mcase's profile
mcase
446 posts in 3155 days
#8 posted 12-21-2010 03:48 AM
SL,
Please be cautious about the dowel systems. I don’t want to start a debate or a lecture. Please investigate the usefulness and longevity of dowels joints on your own. You will probably decide NOT to rely on them.
