MiterSet... have you heard of them?
Forum topic by Joe Lyddon posted 07-06-2017 10:45 PM 4622 views 1 time favorited 56 replies Add to Favorites Watch
View Joe Lyddon's profile
Joe Lyddon
10325 posts in 4256 days
07-06-2017 10:45 PM
Topic tags/keywords: miter jig miter angle set polygon segment miterset miter set fantastic set it - get it no fuss no mess
Hey! I just found out about this Fantastic set of jigs!
Cut Perfect Miter cuts… Cut Perfect segments for polygons!
No MUSS or FUSS… Set it and Cut them!
You MUST SEE THIS fantastic set of jigs! To get absolutely Perfect Miter cuts 100% of the time with NO MESS – NO FUSS! Also, cut perfect segments for Polygons!
Set it and GET IT… for use on Tablesaws, Circular saws, miter saws, router tables, & even at a drill press table!
Unbelievable… BUT TRUE… The best I have ever seen!
Want to make a 7 sided polygon? A 20 sided polygon? (selectable from 4-20 sides)... Set it and start cutting! That simple! NO MESS, NO FUSS, No Test cutting frustrations!
It’s called Miter Set!
I do not have this yet… BUT, I will get it as soon as I can afford it!
See the Demo here!
56 replies so far
View papadan's profile
papadan
3584 posts in 3572 days
#1 posted 07-06-2017 10:56 PM
Sorry Joe, but those jigs would take all the fun out of fixing the fit. ;-)
View GR8HUNTER's profile
GR8HUNTER
5150 posts in 916 days
#2 posted 07-06-2017 11:02 PM
very neat idea Joe …...BUT ....... https://miterset.myshopify.com/products/miterset-package-set ....a little salty in price :<))
View Roger's profile
Roger
20952 posts in 3008 days
#3 posted 07-06-2017 11:13 PM
Very interesting.
Joe Lyddon
#4 posted 07-06-2017 11:13 PM
- GR8HUNTER
Yes, it’s a little pricy…. BUT, just think of all of the frustration LOST in beating your head against the wall to get a Perfect fit of a segmented polygon… or a perfect 45* miter ALL of the time!
If you don’t have problems in getting those, no problem, you are GOOD! ... no sense in buying this!
I wish I could say that… :)
Joe Lyddon
#5 posted 07-06-2017 11:15 PM
- papadan
That “fixing part” is pure frustration to me… LOL
View PASs's profile
PASs
595 posts in 3302 days
#6 posted 07-06-2017 11:29 PM
Neat. Price for the set isn’t bad compared to similar precision jigs.
-- Pete, "It isn't broken, you just aren't using it right."
View doubleDD's profile
doubleDD
7897 posts in 2247 days
#7 posted 07-06-2017 11:47 PM
I was not aware of it Joe. Very impressive jig. If one wants perfect miters every time it’s well worth the price. I will have to check it out further.
View  woodshaver Tony C   's profile
woodshaver Tony C
6231 posts in 3557 days
#8 posted 07-07-2017 01:27 AM
Interesting! Another way to make to get the job done.
-- St Augustine FL, Experience is the sum of our mistakes!
View ArtMann's profile
ArtMann
1158 posts in 1020 days
#9 posted 07-07-2017 01:49 AM
For close to the same money, you can buy an Incra replacement miter gauge that is superior in every way to nearly all OEM miter gauges IMHO. I have had the 1000HD for 10 years or more and it is as accurate now as it was when I bought it. There are other brands for a similar price that I have heard are also good.
View Ken90712's profile
Ken90712
17594 posts in 3393 days
#10 posted 07-07-2017 02:38 PM
Very interesting, while I agree with some of the other comments on Inca miter gauge, which i have. I think the segmented set might have some some real value in it. I’m about to make the easy sled and use the wedges. I think that will work well, if not I might go this route. Thx for sharing.
View jmartel's profile
jmartel
8239 posts in 2354 days
#11 posted 07-07-2017 03:02 PM
I own the basic version of it. Bought it a few years ago. It doesn’t come out much. Handy on occasion, but not enough to justify the now even more inflated price.
GR8HUNTER
#12 posted 07-07-2017 03:14 PM
COME ON Tony ….waiting on your version ….. I know your brains cooking …...LMAO :<))
GR8HUNTER
#13 posted 07-07-2017 03:16 PM
- ArtMann
YES : http://www.rockler.com/incra-miter-gauge-1000 cheaper :<))
View Jack Lewis's profile
Jack Lewis
346 posts in 1282 days
#14 posted 07-07-2017 03:39 PM
Are we working with exotic space age metals or living, breathing, swelling and shrinking wood?
We buy the sharpest cleanest cutting blades, set our expensive miter jigs to .0000001 degree of accuracy, making sure the material is exactly 8% moisture content, in our surgically clean, air conditioned workshop, numbering each piece with sequential accuracy to assure matching grain, then press the finely cut joints together with a water filled glue. Then this glue which is applied in a slightly uneven thickness undetected by the naked eye is squeezed to even more unseen miss thickness to be absorbed randomly between summer and winter growth rings and changing the moisture content uncontrollably and coincidentally the smooth clean cut surface we worked so hard to produce.
ALAS, my foolish Igor, we must pray for a lightning storm to give life to our patient lying helpless on the table!
P.S. That was fun and thank the gods for sandpaper.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View ThistleDown's profile
ThistleDown
48 posts in 921 days
#15 posted 07-07-2017 04:51 PM
+1 on the Incra, I have the 1000SE, which has replaced the one on the saw.
But it does look kool.
-- My biggest fear is that when I am gone, my wife will sell my tools for what I told her I paid for them.
showing 1 through 15 of 56 replies
