Is this doable? Joint a beam?
Forum topic by rmh09 posted 07-06-2017 02:39 PM 776 views 0 times favorited 15 replies Add to Favorites Watch
View rmh09's profile
rmh09
22 posts in 2924 days
07-06-2017 02:39 PM
I have a glulam beam—5 1/8” thick 22” wide and 78” long. I want to use this for a work bench top. After prepping it, I want to add an apron around it. Unfortunately, the length of one side has a round over. That means it will not fit flush with the apron. I have a grizzly 455 10” jointer. Is it possible to just run this one side through/over the jointer 3 or so times (with some help)? My concern is that the beam is VERY heavy, I’d guess something like 150lb.
Thanks!
-- Randy
15 replies so far
View Kazooman's profile
Kazooman
1265 posts in 2187 days
#1 posted 07-06-2017 02:58 PM
Sounds like a very difficult job to pull off. You could consider removing the round over by making a rabbet with a router and filling with a piece of stock.
View Loren's profile
10477 posts in 3882 days
#2 posted 07-06-2017 02:59 PM
Sure. Build an outfeed table for the jointer.
I’ve never done anything that heavy on
a jointer.
You can feed it on the infeed using something
like a roller stand but the outfeed table should
be as perfectly aligned to the the jointer as
possible.
View Richard Lee's profile
Richard Lee
212 posts in 1010 days
#3 posted 07-06-2017 03:10 PM
And the gluelam will ruin your knives, unless they are carbide.
I would do what Kazooman said.
View ThistleDown's profile
ThistleDown
48 posts in 952 days
#4 posted 07-06-2017 03:40 PM
+1 I have done OSB glued up this way to make my own beams. Sharp knifes are needed in the jointer, but never ruined any.
I ve never done anything that heavy on
a jointer.
possible.
- Loren
-- My biggest fear is that when I am gone, my wife will sell my tools for what I told her I paid for them.
View WayneC's profile
WayneC
13794 posts in 4332 days
#5 posted 07-06-2017 03:56 PM
Hand plane worth considering? Move the tool across the wood, not the wood across the tool.
View Aj2's profile
Aj2
1944 posts in 2032 days
#6 posted 07-06-2017 04:04 PM
+ 1 with Kazooman.
-- Aj
View MrRon's profile
MrRon
5261 posts in 3478 days
#7 posted 07-06-2017 04:56 PM
Another +1 with Kazooman.
rmh09
#8 posted 07-06-2017 05:43 PM
Thanks everyone! I am not sure what would ruin the knives, the edge to be jointed is just pine. The beam is glued up 2×6’s (I think). I was most concerned about moving something that heavy across the machine. And that’s also why I wanted to “consider” using the jointer, because I am not good with hand planes yet. Hand planing 6 1/2 feet down 1/4” doesn’t sound like ….fun. Anyway I appreciate your input!
-- Randy
View waho6o9's profile
waho6o9
8539 posts in 2811 days
#9 posted 07-06-2017 05:48 PM
Cut a rabbet and glue in a filler piece
+1 with Kazooman
View jonah's profile
jonah
1971 posts in 3533 days
#10 posted 07-06-2017 06:44 PM
I’m with everybody else. Rabbet it.
Richard Lee
#11 posted 07-06-2017 07:23 PM
Thanks everyone! I am not sure what would ruin the knives, the edge to be jointed is just pine. The beam is glued up 2×6 s (I think). I was most concerned about moving something that heavy across the machine. And that s also why I wanted to “consider” using the jointer, because I am not good with hand planes yet. Hand planing 6 1/2 feet down 1/4” doesn t sound like ….fun. Anyway I appreciate your input!
- rmh09
I thought it was like a piece of plywood.
rmh09
#12 posted 07-06-2017 07:29 PM
Begrudgingly ….the overwhelming recommendations are for a rabbit and a filler piece. I hate it when I think I have a “good” idea that’s only slightly dangerous. Now that I know, I have to listen to good advice and I am fairly sure that I will do a rabbit and filler. Thanks again!
-- Randy
View Aj2's profile
Aj2
#13 posted 07-06-2017 07:49 PM
It’s the glue in engineered beams that’s hard on steel knives.Even if you can stay away from it most likely your beam has been siting on the ground and has dirt or sand embedded on the face and that’s a knife killer too.
Good luck and stay dangerous I meant safe.:)
-- Aj
View AlaskaGuy's profile
AlaskaGuy
4982 posts in 2544 days
#14 posted 07-06-2017 08:00 PM
Just an idea.
Perhaps you could take a router with a rabbet bit and rabbet out the round overs and glue a square back in. You could even use a colorful contrasting wood if that appeals to you or use a matching wood.
View Kelly's profile
Kelly
2180 posts in 3179 days
#15 posted 07-06-2017 10:12 PM
My friend sent is kid over to learn some woodworking tricks (what a fool). His project was to restore a 12’ long, redwood picnic table made from an old wine vat. One of the seat joints had failed and I had to cut it apart at the center, run it through the jointer then put it back together. The kid was scarce (surprise), so I did it by myself. The two 1-1/2” x 6” x 12’ pieces went back together nicely.
Had I had to do it with your beasts, I think it would have been even easier, since it would hold itself down and would only need support at the ends and when moving them back and forth. Of course, the weight would have called for two people to move it back to start each time.
Because yours is so wide, a temporary fence would be in order too.
