can I laminate boards for this project or do I need larger stock?
Forum topic by leftcoaster posted 07-06-2017 01:46 PM 1050 views 0 times favorited 8 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
220 posts in 902 days
07-06-2017 01:46 PM
I’m interested in building John White’s New-Fangled Workbench, which is made from surfaced dimensional lumber (doug fir). Haven’t bought the plans yet but I do have the article from FWW and he says he used kiln dried 2×10s and 2×12s so that he could be choosy about what to use where.
The lumberyards near me have kiln dried 2×4s but only green wood in larger sizes. I don’t have the space to dry it for months myself.
Looking at the legs and stretcher—could I laminate 2×4s to get the wider stock? Or should I make a somewhat lengthy trek to a yard that has larger KD lumber? They will transfer boards closer to me, but only in the amount I need, which means I can’t choose boards.
https://www.tauntonstore.com/new-fangled-workbench-065113.html
8 replies so far
leftcoaster
#1 posted 07-06-2017 01:51 PM
No sooner did I post this than a contractor friend let me know of a somewhat nearby yard that has what I need. Thanks!
View TheFridge's profile
TheFridge
9608 posts in 1511 days
#2 posted 07-06-2017 01:52 PM
Laminating is perfectly fine
View builtinbkyn's profile
builtinbkyn
2365 posts in 966 days
#3 posted 07-06-2017 02:06 PM
Interesting bench. Here’s a link with a video of how it’s used and operates.
http://www.finewoodworking.com/2007/03/23/new-fangled-workbench-revisited
-- Bill, Yo!......in Brooklyn & Steel City :)
View jonah's profile
jonah
1727 posts in 3324 days
#4 posted 07-06-2017 02:18 PM
2×4s are fine in a pinch, but not optimal because you can’t cut around knots and pith. With 2×10s or 2×12s, for example, you can cut the pith out of the center (lots will have pith in them) and theoretically end up with quarter-sawn boards. And you can still get a 3-4 inch thick top. 2×8s you will likely not be able to cut around knots as easily, since you have less width to work with. If you want a 3” thick top, 2×10s are the sweet spot IMO.
leftcoaster
#5 posted 07-06-2017 02:41 PM
Would you all expect this bench to have enough weight to not move around when planing? And would the doug fir stay flat?
builtinbkyn
#6 posted 07-06-2017 02:43 PM
This bench uses the face grain as the work surface. Good quality kiln dried 2×4s will work for pretty much the entire build, from what I see. Easier on the back when loading and unloading ;)
builtinbkyn
#7 posted 07-06-2017 02:44 PM
- leftcoaster
Well the FWW guy uses it every day. Looks like a good tool. He did make it very long, so that adds to the heft. Those long pipe clamps and the other accessories stored on the bench also help with your concern.
leftcoaster
#8 posted 07-06-2017 03:28 PM
Here’s a lumberjock who did a nice set of modifications that add more heft.
Reading around it looks like some folks made a few mods borrowed from the Roubo, notably bringing the legs all the way to the edge of the top rather than having an overhang. On the backside that certainly makes sense to me. I’m unclear about whether it’d would make sense on the front—I don’t know enough about the reason for that aspect of the Roubo design.
- leftcoaster
- builtinbkyn
