Craftsman Table Saw Pulley Installation
Forum topic by texasweaver posted 07-06-2017 12:27 PM 482 views 0 times favorited 3 replies Add to Favorites Watch
View texasweaver's profile
texasweaver
3 posts in 443 days
07-06-2017 12:27 PM
Topic tags/keywords: tablesaw
I’m perplexed about replacing pulleys. Do I first slide the pulley on the saw blade shaft the drive in the shim. It is probably simple but a first for me.
3 replies so far
View sawdustdad's profile
sawdustdad
364 posts in 1002 days
#1 posted 07-06-2017 01:22 PM
You mean key? Not shim. The pulley should slide on the shaft with the key in place. If it’s not going well, clean the key with some fine sandpaper. The fit should be close, with little to no slop but not so tight you need to hammer the pulley on.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
texasweaver
3 posts in 443 days
#2 posted 07-14-2017 12:53 PM
You mean key? Not shim. The pulley should slide on the shaft with the key in place. If it s not going well, clean the key with some fine sandpaper. The fit should be close, with little to no slop but not so tight you need to hammer the pulley on.
- sawdustdad
texasweaver
3 posts in 443 days
#3 posted 07-14-2017 12:54 PM
Thanks for the help, much appreciated!
