Need a new planer with a small footprint
Forum topic by McFly posted 07-05-2017 06:27 PM 864 views 0 times favorited 16 replies Add to Favorites Watch
View McFly's profile
McFly
273 posts in 1227 days
07-05-2017 06:27 PM
Looking to buy a new planer for my home shop, which is 3/4 of a 1 car garage, so a small footprint is a must. I do a fair amout of work at home, so it will need to run for hours on end.
Is there an American made brand that stands out above the rest?
prefer to look at old American iron first if possible – though they tend to run on the larger side – but will look into new machines if they’re worth it.
16 replies so far
View BenjaminNY's profile
BenjaminNY
134 posts in 1602 days
#1 posted 07-05-2017 06:33 PM
Woodmaster is made in made in the USA and is reasonable in price. Other than that, only northfield comes to mind for USA made and northfield is extremely expensive.
Most planers in the 12 to 20 inch range are going to take up a similar footprint.
I would look for something with a good mobility kit if space is tight or spend the money on a felder combo machine to get a good sized jointer as well.
View ArtMann's profile
ArtMann
1142 posts in 1016 days
#2 posted 07-05-2017 06:38 PM
It has been many, many years since I saw a small planer advertised that was made in the US. I don’t want to discourage you from buying American but there are zero new choices and not very many old choices that are small enough for your needs. If you have to buy new, your best choice could be the Dewalt 735. It gets a lot of praise. I now have a Jet jointer/planer combo machine but when I had a small planer, it was a Ridgid TP1300 lunchbox planer. It earned its purchase price a hundred times over.
ArtMann
#3 posted 07-05-2017 06:47 PM
Having read Benjamin’s post, I have to agree that Woodmaster is an option. I hadn’t thought of them. They offer the very useful option of converting over to a molder. Even their smallest one is fairly expensive for what you get but it may be worth it to you.
Felder is not an American company and isn’t made in the US, but I hear they are excellent machines. They are a little large and expensive for 3/4 of a garage bay but may be worth it. I would recommend my Jet JP12-HH machine but with a few caveats.
View bbasiaga's profile
bbasiaga
1240 posts in 2195 days
#4 posted 07-05-2017 07:11 PM
Any of the 12 to 13 inch models can be put on a flip top cart and share the same floor space with another tool.
Brian
View teejk02's profile
teejk02
486 posts in 1325 days
#5 posted 07-05-2017 07:36 PM
Brian
- bbasiaga
I keep my Delta 13” on top of my rolling tool cabinet. Heavy duty construction and I need the tools anyway.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3114 days
#6 posted 07-05-2017 08:13 PM
While this is not exactly what you may want, think about how you can combine an assembly table to incorporate a planer. The infeed/outfeed could serve as your work surface when you aren’t using the planer. Just an idea. My “cart” is 24”x24”x96” with locking casters.
View Loren's profile
10477 posts in 3848 days
#7 posted 07-05-2017 08:26 PM
The Belsaw is a good planer but chip collection
is poor. They aren’t too heavy, maybe 250 lbs.
Woodmasters and RBI planers are similar, come
in widths wider than the Belsaw’s 12”. At some
point Powermatic bought the rights to one
of these planers, forget which one, and sold
them badged Powermatic. Belsaws were also
badged Craftsman.
In older planers most anything over 12” is
going to be quite heavy to move. The Delta
12” planers are said to be quite good.
One advantage of the Belsaw style planers is
you can see easily how everything works.
The feedworks is open rather than enclosed
and the makers still supply parts. Belsaw
parts are reasonably priced.
The achilles heel of old planers is a knackered
feedworks. If you’re considering buying
one take a close look at that.
View Jim Finn's profile
Jim Finn
2687 posts in 3122 days
#8 posted 07-05-2017 11:12 PM
I have a shop a bit larger than yours but I once had one about the size of the original poster. I had a Ryobi 12” planer that works well for me but dust collection was lousy. I then bought a DeWalt 735 and it has powerful dust/chip extraction. I would recommend either of those.
-- No PHD just a DD214 Website> craftingcouple.com
View dhazelton's profile
dhazelton
2793 posts in 2497 days
#9 posted 07-05-2017 11:24 PM
Sears alien planer?
View sawdustdad's profile
sawdustdad
366 posts in 1085 days
#10 posted 07-05-2017 11:48 PM
My first planer (30 years ago) was a 12 inch woodmaster planer/molder. 5hp. I put it on locking casters to allow me to move it around the shop. While I replaced it’s planing duties with a 20 inch Grizzly about 15 years ago, I still use the Woodmaster for moldings.
The Woodmaster is a beast. It rattles and shakes a little, but it’s all standard hardware, so it’s easy to see how it works. It performed for me flawlessly for years, on thousands of bd ft of hardwoods and softwoods. It would take a 1/4 inch cut if you wanted to.
In some respects, I prefer it over the Grizzly because the rubber feed rollers would allow you to take whisper thin cuts (serrated feed rollers of the Grizzly mark the wood on infeed, forcing you to take at least 1/32 to clean up the marks).
The Woodmaster had a smooth lower table rather than the table with imbedded rollers in the the Grizzly. The rubber feed rollers had no trouble pushing the wood through. The Grizzly’s (and many others) lower table feed rollers can be tricky to set.
And, like I said, if you want to hog some wood off the boards, the Woodmaster will take much heavier cuts than the Grizzly is capable of (due to machine geometry, not horsepower).
The RBI planer is similar from what I understand, though I have no personal experience.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
McFly
#11 posted 07-06-2017 12:25 AM
Good info all around. Plenty of food for thought here.
View Woodchuck2010's profile
Woodchuck2010
722 posts in 1058 days
#12 posted 07-06-2017 02:14 AM
+1 for the Dewalt 735. Dust collection is excellent!
-- Chuck, Michigan,
View jonah's profile
jonah
1921 posts in 3499 days
#13 posted 07-06-2017 02:43 AM
That 180 degree bend has to be killing your airflow!
View GR8HUNTER's profile
GR8HUNTER
5121 posts in 913 days
#14 posted 07-06-2017 02:53 AM
I’m guessing he pulls it out from wall then it would be a nice run …..clean floor Chuck :<))
Woodchuck2010
#15 posted 07-06-2017 09:25 PM
- jonah
It actually worked good. I have ,
however, changed the run. It works great! I’m not sure if you know, but the 735 has a crazy strong blower to help with dust extraction. I’ve forgotten to turn on the collector a couple of times and you’d never know it. The chips get blown right into the collector.
-- Chuck, Michigan,
