| Forum topic by Andy Needles | posted 885 days ago | 1491 views | 0 times favorited | 7 replies | ![]() |
885 days ago |
Topic tags/keywords: finishing Hello all, I’m having a hard time with a final finish (happens to be water based poly), and getting the finish lookiing even/not mottled. To be more specific- I’m talking about the top layer (not in the wood or the finish). I tried lightly rubbing it, but went too far, and spraying another coat have left an uneven sheen. I was looking for others’ buffing tips/techniques, rather thn a daignosis of the issue (uneven sheen on the top surface) Its a pretty flat, built up, dark walnut surface that continues to show an uneven sheen even after spraying twice that I want to buff or rub out. Please share your tips, buffing techniques with the team!! Thanks for your ideas!!! Andy -- rustic andy |
7 replies so far
#1 posted 885 days ago |
Andy, -- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952) |
#2 posted 885 days ago |
IMNSHO, the poly is the culprit. I have quit using the stuff ‘cause I want a much more “classic” finish. I’m now using a wiping varnish for furniture, shellac for display pieces, some oil where applicable. Only use poly for high abrasion surfaces. I still think that NC lacquer is a great finish. -- bill@magraphics.us |
#3 posted 884 days ago |
I agree with Roger, you need to supply more information in order for anyone to offer reliable advice. -- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it. |
#4 posted 883 days ago |
Andy, Post a pic if you can, but if I read you correctly, You’re not going to buff this out. If you had scratches or uneven sheen and shot another coat over it, you buried it. Water-based doesn’t burn in or dissolve and blend with the last coat like laquer or shellac, but lies on top and leaves “witness lines”. Your only choice is to sand the whole thing down, get a smooth surface, and start over. A properly applied, sprayed finish should need minimal buffing. For info on how to buff to an extreme gloss, go to www.finewoodworking.com and search in finishing. There’s a wealth of info there. Steve -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#5 posted 883 days ago |
In my experience, it takes many coats of poly on walnut to get to a point where you can rub out to a consistent sheen. The grain in some areas will soak up more finish than in other areas, hence the inconsistent gloss level. A method I have used with success is to apply a number of coats to really get the surface built up, then sand back with 400 grit to level everything off. The result at this point will be milky and ugly looking, but don’t worry.. the final coat will restore the sheen, and now you will have a surface thick enough to rub out without going through. -- Charlie M. "Woodworking - patience = firewood" |
#6 posted 883 days ago |
What kind of wb poly? The one I use (Target) does burn in up to about 24 hours coat separation, but if you sand through that last group of coats you will get witness lines and have to go back to square one. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#7 posted 872 days ago |
You need a enough film layer if you want to rub your finish. Good luck wisn |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3548 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
