Pinning Breadboard Ends on a cutting board?
Forum topic by SgtRich posted 07-05-2017 03:32 PM 511 views 0 times favorited 1 reply Add to Favorites Watch
View SgtRich's profile
SgtRich
55 posts in 2048 days
07-05-2017 03:32 PM
The quick question:
Given the smaller size and ripped strips of board glued together, how necessary is it to pin Breadboard ends on a cutting board?
Can a glued spline work just fine?
Granted, I may try pinning a couple just for the practice of it…but I would be interested if pinning on a cutting board versus a glued spline would be overkill?
-- Every day is another opportunity to create something great. srich45251@gmail.com
1 reply so far
View BenjaminNY's profile
BenjaminNY
134 posts in 1639 days
#1 posted 07-05-2017 06:38 PM
If it is a straight pin instead of a tapered plug I would lean against it. The board is going to get wet all the time and the pins will likely be the first place where ugly gaps show up.
Maybe experiment first before you do it with any precious wood.
