Anyone use a microplane rotary shaper?
Forum topic by patcollins posted 12-18-2010 07:11 PM 3518 views 0 times favorited 3 replies Add to Favorites Watch
View patcollins's profile
patcollins
1683 posts in 2831 days
12-18-2010 07:11 PM
I have been using a sanding drum on my drill press but saw these and wondered if anyone ever used one and what you thought of it?
3 replies so far
View Gene Howe's profile
Gene Howe
10355 posts in 3394 days
#1 posted 12-18-2010 07:47 PM
I like it. Still must sand but great for hogging. The pattern follower is great!
View mvflaim's profile
mvflaim
189 posts in 3057 days
#2 posted 12-18-2010 08:43 PM
They work really nice. Cut really well and are aggressive.
View SteveMI's profile
SteveMI
1092 posts in 3260 days
#3 posted 12-18-2010 09:40 PM
Very aggresive! I got the 1” version from Lee Valley over a year ago. Make sure you use some scrap wood to get a feel for how it works. Wrong speed for the hardness of wood and you do get chatter, so try a different speed setting if that happens. For the right use they are awesome. I have trouble getting the pattern follower to work as well as I thought it should, but that could have been me.
They say “Use as an alternative to coarse sandpaper” and that must mean #60 or #80 grit, because the surface does need sanding afterwards.
One other thing is that they are a great alternative to a router bit on wood where you have a problem with tear out. I’ve used it for sweeping curves that would have been a tear out looking to happen with a router bit.
Steve.
