bandsaw flywheel pulley issues
Forum topic by shimasaki posted 07-05-2017 12:45 AM 251 views 0 times favorited 1 reply Add to Favorites Watch
View shimasaki's profile
shimasaki
1 post in 233 days
07-05-2017 12:45 AM
I am having a problem with the lower flywheel pulley on my Craftsman band saw. When I turn the band saw on, the wheel wobbles off. I have tightened the locknut on the key as tight as I can and it still wobbles off. Any suggestions as to how to remedy this issue? Please advise. Thanks.
1 reply so far
View johnstoneb's profile (online now)
johnstoneb
2793 posts in 2080 days
#1 posted 07-05-2017 02:36 AM
Get a pulley that is sized for that size shaft. It sounds like your pulley has been run loose for quite awhile and egg shaped the hole. If that is the case you can’t tighten the set screw enough to keep it tight. you need to replace the pulley.
-- Bruce, Boise, ID
