Sealing end grain to protect during soaking
Forum topic by RipFence posted 07-04-2017 04:20 PM 502 views 0 times favorited 10 replies Add to Favorites Watch
View RipFence's profile
RipFence
77 posts in 2890 days
07-04-2017 04:20 PM
Hello All:
I am working on a couple of Stickley 336 Morris chairs with steam bent arms. Soaking dried Qsawn oak in water and fabric softener allows steam bending but I am getting pretty bad checking in the end grain. Bad as in throw it away. I’m going to try the whole process again but with some sort of sealer on the ends.
Should I use anchorseal or might there be a cheaper alternative? I was thinking of just dipping the ends in molten paraffin.
Thanks,
Jim
10 replies so far
View Loren's profile
10477 posts in 3845 days
#1 posted 07-04-2017 04:25 PM
Those chairs have a pretty modest bend
as I recall. I think your problem is immersing
the wood in water. Hot steam in a box is
preferable and results tend to be acceptable.
You can try sluicing boiling water over the
boards and quickly bending afterwards while
the wood is still hot. Boat sides are sometimes
bent this way I think.
View CharlesNeil's profile
CharlesNeil
2457 posts in 4067 days
#2 posted 07-04-2017 04:43 PM
i do this all the time, first off White oak , while it bends well is tough to dry .. it likes to honey comb and split .
while shellac is not the best sealer when it comes to moisture , it is compatible , its alcohol based and alcohol and water mix, you want seal the ends down ASAP but let them dry a little several hours.
I agree , steam only … skip the fabric softener and soaking .. over kill
when bending any thing , ALWAYS bend over length … leave room to trim back .. end splits can happen
Slow the dry , get put them in plastic or whatever .. especially white oak .
I have also put clamps across the ends to help , as it dries
wood dries the most thru the ends, so sealing it and clamping it will force it to dry slower , even a plastic bag over the end will help …
View Rich's profile
Rich
3869 posts in 786 days
#3 posted 07-04-2017 05:17 PM
- CharlesNeil
Charles, what’s honey comb (other than a Jimmie Rodgers song)?
RipFence
#4 posted 07-04-2017 05:18 PM
Thanks Loren and Charles. Let me give a bit more background: The radius is 72” but I could not get any of my dried stock to take that much bend. After soaking in fabric softener it bends nicely and only springs back about 20% so I have been using a 60” radius form. This works fine except for the checking.
I have a couple of test pieces soaking now with paraffin sealed ends and will try only soaking for a day. I had been soaking for two weeks following advice I read about making hockey sticks. I’ll also see about sealing the ends again immediately after I clamp them so they dry more slowly.
Thanks,
Jim
View AandCstyle's profile
AandCstyle
3177 posts in 2454 days
#5 posted 07-04-2017 09:06 PM
Jim, another option would be to resaw the pieces to about 1/4” and make a bending form with the appropriate radius then glue the lams back together in the same order. The seams will be invisible. Here is my first ever attempt and it worked great. FWIW
-- Art
View Woodknack's profile
Woodknack
12429 posts in 2577 days
#6 posted 07-04-2017 09:19 PM
Heat allows bending. Steam helps get heat inside the wood and prevents scorching. I’ve never heard of water + fabric softener, perhaps that’s more advanced than my experience. The only time I’ve soaked wood was relatively thin material that was bent around bending irons.
View AlaskaGuy's profile
AlaskaGuy
4760 posts in 2506 days
#7 posted 07-04-2017 10:08 PM
- CharlesNeil
Charles, what s honey comb (other than a Jimmie Rodgers song)?
- RichTaylor
I know you want Charles to answer but in the mean time.
Part B
https://ir.library.oregonstate.edu/xmlui/bitstream/handle/1957/1495/FPL_1369_ocr.pdf;jsessionid=99C9400FCB6BD2EBE2A3F11E3840E147?sequence=1
View Rich's profile
Rich
#8 posted 07-04-2017 10:45 PM
Part B
- AlaskaGuy
I should have looked it up myself, AG. I had no idea it was a technical term, just figured it was woodworker’s slang. Thanks for jumping in and clearing it up.
View Kazooman's profile
Kazooman
1236 posts in 2149 days
#9 posted 07-05-2017 09:52 PM
I may be missing something, but can’t you just cut the pieces way long prior to bending, bend, and trim to size cutting the checked ends off in the process? Is there some sort of tenon or something like that on the ends that requires having the pieces be final length prior to bending?
RipFence
#10 posted 07-05-2017 10:06 PM
No reason I can’t do that and I should have done it on the first round. I’ll cut up those checked boards to see how deep the cracks go.
