How to stain end grain properly
Forum topic by ColonelTravis posted 07-04-2017 04:12 AM 496 views 0 times favorited 4 replies Add to Favorites Watch
View ColonelTravis's profile
ColonelTravis
1744 posts in 1799 days
07-04-2017 04:12 AM
Topic tags/keywords: end grain stain
Made a wood base out of maple for something insignificant, stained it and wasn’t thinking because I don’t typically stain things. The end grain obviously sucks in a lot. In this particular case it doesn’t matter, but for future reference what’s the best way to make sure stained end grain doesn’t look like garbage?
By the way, I used Charles Neil’s blotch control – it’s fantastic. If you’re staining wood that blotches, get this stuff.
View Loren's profile
9948 posts in 3553 days
#1 posted 07-04-2017 04:18 AM
I find end grain in hardwoods benefit from
meticulous hand sanding. You might want
to check your progress with mineral spirits.
Some woods like oak are pretty forgiving but
others are not.
View skogie1's profile
skogie1
105 posts in 1268 days
#2 posted 07-04-2017 04:42 AM
I find that sanding end grain to a very fine grit helps prevent excess absorption. I’ve gone as high 600 if I remember correctly and it did the trick, that plus some sealer.
View Rich's profile (online now)
Rich
2282 posts in 494 days
#3 posted 07-04-2017 06:14 AM
+1 on the fine grit sanding. Applying a 1/2 lb cut of seal coat and letting it dry before the sanding helps (1/4 Bullseye Seal Coat, 3/4 denatured alcohol).
-- No matter how much you push the envelope, it'll still be stationery.
ColonelTravis
#4 posted 07-04-2017 05:11 PM
Did not do any of that, will try it next time.
Thanks.
