Routing Inlay Beginners Question
Forum topic by Elksniffer posted 12-17-2010 09:38 PM 1320 views 0 times favorited 3 replies Add to Favorites Watch
View Elksniffer's profile
Elksniffer
101 posts in 3396 days
12-17-2010 09:38 PM
Topic tags/keywords: question
I am beginning an inlay for a cutting board and have confused myself about the direction of travel to move the router and creating a climbing cut. Let’s say you are routing a circle. Would you always move the router in a clockwise direction? On part of the circle would it be a climbing cut? Thanks in advance for clearing the fog I have created.
Jeff
3 replies so far
View TomHintz's profile
TomHintz
207 posts in 3397 days
#1 posted 12-17-2010 10:41 PM
Yes, keep going in the right direction. Part of the cut will be a climb cut with such a small bit you can get away with it pretty easily.
-- Tom Hintz, www.newwoodworker.com
View shipwright's profile
shipwright
7980 posts in 2797 days
#2 posted 12-18-2010 09:57 AM
If you are using an inlay bushing set, Going around a female pattern clockwise will always be into the grain and will hold the router against the pattern. Going counter-clockwise will always be a climb cut and you will have more trouble following the pattern. With these sets cutting the hole is not as critical as cutting the inlay because if the bit wanders from the pattern when you are cutting the hole you are wandering into the waste area that you are taking out anyway. If however you wander from the pattern when cutting the inlay piece, you’ve ruined the inlay piece.
View Chiefk's profile
Chiefk
163 posts in 3770 days
#3 posted 12-18-2010 03:29 PM
Elksniffer, normally you route in a clockwise direction when hand routing. The cutter will turning into the workpiece. To clime cut, you would go in a counterclockwise direction. This is a little more dangerous as the cutter is turning in the same direction you are routing, because of this the router is more difficult to control. There are times when a clime cut is desirable because of the grain direction of the wood. pkennedy
-- P Kennedy Crossville, TN
