Circular Blades
Forum topic by Austinpeay posted 07-03-2017 08:47 PM 1016 views 0 times favorited 8 replies Add to Favorites Watch
View Austinpeay's profile
Austinpeay
28 posts in 561 days
07-03-2017 08:47 PM
Topic tags/keywords: circular saw miter saw table saw 7 7 14 8 9 10 12 14 16 resource
Helping a buddy of mine clear up his estate so he can relocate. I have the below listed blades for sale. They have been listed on eBay under seller name tntravler with the prices as noted below. Thanks,
60 tooth Master Mechanic 8” Hollow Ground Planer Circular blade 117.820 1 $12.01
Black & Decker Piranha 7-1/4” 35T carbide tipped 35 teeth 73-707 Planer combo 1 $12.01
Delta 10” 36T ATB Carbide Tipped 36 tooth 15 hook 1 $25.01
Delta 12045 8-1/4” combination circular saw blade 1 $12.01
Delta 24T 19
Thin Kerf carbide tipped blade no packaging 2 $12.01
Delta 34-708 9” 44T tooth combination rip saw blade carbide tipped 1 $8.01
Delta 35-025 8-1/4” 18T ATB Sidekick ripping blade no packaging 2 $18.01
Delta 35-027 8-1/4” 35T ATB&R Sidekick combination no packaging 1 $18.01
Delta 35-035 10” 80T ATB extra fine carbide blade 80 tooth 1 $40.01
Delta 35-533 8” Cross cut Flooring Circular blade 1 $25.01
Delta 35-561-R 8” 24T D circular blade 24 tooth 1 $12.01
Delta 35-591 8” 24T ATB circular blade 24 tooth carbide tipped general purpose 1 $12.01
Delta 35-592 8” 64T ATB circular blade 64 teeth 1 $50.01
Delta 35-593 8” 48T TC&F circular blade 48 teeth 4 $50.01
Delta 35-597 40T ATB carbide tipped circular saw blade 40 teeth 18 hook 1 $45.01
Delta 35-599 10” 50T ATB 16
Hook – no packaging 1 $35.01
Delta 35-600 9” 80T TC&F circular blade 80 tooth used 1 $25.01
Delta 35-603 9” 24T ATB circular blade 24 tooth used 1 $19.01
Delta 35-610 10” 10T carbide tipped 10 teeth no packaging 1 $28.01
Delta 35-610 10” 10T FT industrial carbide tipped saw blade 10 tooth rip ripping 1 $28.01
Delta 35-611 10” 18T F industrial carbide blade 18 tooth 1 $19.01
Delta 35-612 10” 24T ATB industrial carbide tipped saw blade 24 tooth 1 $22.01
Delta 35-742 10” 80T ATB industrial carbide saw blade 80 tooth melamine laminate 3 $31.01
Delta 35-750 8” 34T ATB thin kerf circular blade 24 tooth used 2 $20.01
Delta 35-751 8” 64T ARB circular blade 64 tooth thin kerf 1 $40.01
Delta 35-752 10” 40T ATB industrial carbide tipped saw blade 40 tooth thin kerf 1 $24.01
Delta 35-754 10” 80T ATB industrial carbide blade 80 tooth grained composition 1 $41.01
Delta 422-34-009-0001 8 1/4 20t Carbide Tip test blade no packaging 2 $14.01
Delta Sidekick 35-000 6-1/2” 40T carbide tipped Circular blade 40 teeth ATB 0 1 $18.01
Delta Sidekick 35-011 7-1/4” 24T carbide tipped ATB combination blade 24 teeth 1 $12.01
Delta Sidekick 35-012 7-1/4” 40T carbide tipped ATB Circular blade 40 teeth 1 $12.01
Delta Sidekick 35-018 10” crosscut flooring blade sealed packaging 1 $40.01
Delta Sidekick 35-031 40T ATB carbide tipped circular saw blade 40 teeth 1 $39.01
Delta Sidekick 35-032 50T ATB&R carbide tipped circular saw blade 40 teeth 1 $38.01
Delta Sidekick 35-034 10” 60T TC&F carbide tipped 60 teeth no packaging 1 $31.01
Irwin Marathon 8” 30T C3 Carbide Tipped 14050 1 $21.01
Master Mechanic 440875 8-1/4” 40T smooth cut combination circular saw blade 1 $12.01
Oldham 10060TP 10” 60T carbide blade 60 tooth 2 $18.01
Oldham Super Duty 7-1/4” 24T C3 tungsten carbide tipped blade 725C424 1 $12.01
Portalign DeltaBlade 71/4” Circular Saw Blade Triangle Cut Corners NOS 1 $12.75
Porter Cable 12152 6” thin kerf plywood circular blade 1/2” arbor 1 $15.01
Porter Cable 12801 Riptide 7-1/4” 18T ATB thin kerf carbide tipped blade 1 $15.01
Porter Cable 12810 Riptide 7-1/4” 24T thin kerf carbide tipped circular blade 1 $18.01
Porter Cable 12840 Riptide 7-1/4” 38T thin kerf carbide tipped circular blade 2 $50.01
Porter Cable 12911 Riptide 10” 40T ATB carbide blade 40 tooth 13
Hook 1 $31.01
Porter Cable 12912 Riptide 10” 60T ATB carbide blade 60 tooth 10* Hook 1 $31.01
Porter Cable 87015 7-Inch Dry Cutting Continuous Rim Turbo Diamond Saw Blade 1 $25.01
Porter-Cable Premium 7 inch Wet Cutting Continuous Rim Diamond Saw Blade 87027 1 $30.00
Porter-Cable Riptide 12” 40T tooth ATB saw blade 12920 thin kerf carbide tipped 1 $25.01
Roc-Edge Sharp Master 10” 100T precision steel 100 teeth 7501 1 $12.01
Rockwell 12203 7-1/4” 12T tungsten carbide tipped 12 teeth 1 $12.01
Utility King Karbide King 8” 20T carbide tipped Circular blade 20 teeth ATB 1 $12.01
Woodworkers Signature 10” 50T Planer Combination 50 tooth premium carbide 2 $35.01
Delta 35-825 Carbide-tipped 7 “ 16T Adjustable Dado Set 2 $21.01
8 replies so far
View jbay's profile
jbay
2876 posts in 1100 days
#1 posted 07-03-2017 09:03 PM
Gotta ask, what is with the XX.01 prices. Is that the built in price for negotiating?
Austinpeay
#2 posted 07-03-2017 09:05 PM
The .01 was to let me know that they were listed on the first of the month. If you want offer on any please let me know.
View knotscott's profile
knotscott
8147 posts in 3576 days
#3 posted 07-03-2017 09:07 PM
New or used?
View Bill White's profile
Bill White
5124 posts in 4161 days
#4 posted 07-03-2017 09:09 PM
Wahhhh! Without a total package price, you’re not representing the whole bunch of blades.
What if someone wanted to buy all?
Bill
-- bill@magraphics.us
Austinpeay
#5 posted 07-03-2017 09:29 PM
I’d have to talk to him and see what he’d take. The shipping on all would be a killer they are steel you know.
If you’re interested I’ll ask him for a price.
Austinpeay
#6 posted 07-03-2017 09:36 PM
The majority are new – a few of them have had a few test cuts on them. If you’re interested in a particular blade let me know and I’ll look at it. Thanks
View Aj2's profile (online now)
Aj2
1874 posts in 1998 days
#7 posted 07-03-2017 10:17 PM
Does he have any blades with 3/4 hole he sure likes delta.
-- Aj
Austinpeay
#8 posted 07-03-2017 10:20 PM
just the ones listed – he is retired Rockwell/Delta/Porter-Cable/Black & Decker/Stanley Black & Decker employee – he made it from the Rockwell to the file incarnation
