Very nice stanley no 4 find today, how should I approach restoring it?
« back to Hand Tools forum
Forum topic by Marn64 posted 07-03-2017 07:24 PM 3712 views 0 times favorited 20 replies Add to Favorites Watch
View Marn64's profile
Marn64
295 posts in 779 days
07-03-2017 07:24 PM
Topic tags/keywords: question plane
Hey everyone,
I went to my local Habitat for Humanity ReStore today and I found this real pretty Stanley no 4. I believe it is somewhere in the range of type 7, 8, or 9, but I am not sure. It still has really nice Japanning and not a lot of paint splatters all over it as is so very common in rusty planes. I have had some issues with citric acid dulling japanning in the past and I don’t want to do that to this one, any ideas?
-- Benjamin, Milwaukee
20 replies so far
View chrisstef's profile
chrisstef
17378 posts in 3000 days
#1 posted 07-03-2017 07:57 PM
Evaporust will be the ticket if you didnt like citric. If rust gets under the jappaning youll get some flaking no matter what you use though. I suspect that was the problem with the CA.
Nice find!
View Loren's profile
10373 posts in 3642 days
#2 posted 07-03-2017 08:01 PM
I wash the plane with soapy water to clean
the Japaning. Leave it out in the sun to dry,
then I wire brush the rust off and work it
over with fine stearated sandpaper to get
the rust out of the grain of the iron. Then
wax.
View JCamp's profile
JCamp
563 posts in 544 days
#3 posted 07-03-2017 08:06 PM
I’ve not restored many but I lik white vinegar to take the rust off tools
-- Whatsoever thy hand findeth to do, do it with all thy might
View Bill White's profile
Bill White
4928 posts in 3954 days
#4 posted 07-03-2017 09:13 PM
That is an old puppy. Go lightly no matter what you use.
Bill
-- bill@magraphics.us
View Ocelot's profile
Ocelot
1974 posts in 2632 days
#5 posted 07-03-2017 10:18 PM
I’m a fan of evaporust. Just run it (less the wood) through the dishwasher, the soak in Evapo-Rust. Go easy on wire brushing. Try plastic brush, then brass, steel only as last resort.
It looks like not much meat on the blade, so surely don’t use a power grinder.
-Paul
Marn64
#6 posted 07-04-2017 04:11 AM
Thanks for the responses, I figured out the type study by the way, it is earlier than I thought. It is a type 6, which dates it to 1888-1892.
View TheFridge's profile
TheFridge
9444 posts in 1480 days
#7 posted 07-04-2017 04:18 AM
I love me some low knobs.
View mski's profile
mski
439 posts in 3974 days
#8 posted 07-04-2017 05:46 AM
OH YES I just got one too type 9. , also consider through the years people could have bought different parts for repair so only the body casting is time telling. look here
http://www.hyperkitten.com/tools/stanley_bench_plane/dating_flowchart.php
Having a hard time getting my iron flat but everything else going good keep us posted
-- MARK IN BOB, So. CAL
View mski's profile
mski
#9 posted 07-04-2017 06:00 AM
OOPS I got side tracked about your question
DON’T acid bath it !!!
DON’T Rust magic it !
NO Vinegar !!!
All the metal just soak in a penetrating oil like PB Blaster Kroil etc then brush with steel wool scotchbrite or the like only work on rusty portions, Flatten the sole, iron, breaker and frog.
100+ years to get a patina and ruin it with rust buster YIKES !!!!!!!!
View jonah's profile
jonah
1695 posts in 3293 days
#10 posted 07-04-2017 10:57 AM
If you’re going to be using the plane to, you know, actually plane wood, who gives a damn about the patina? Evapo-Rust is what I use. It works great. Electrolysis on very large things that I can’t easily submerge in Evapo-Rust.
In this case, Evapo-Rust is the ticket. Pick up a gallon at Harbor Freight with the 25% off coupon today and you’ll be out the door for less than $20.
View chadirvin's profile
chadirvin
34 posts in 2033 days
#11 posted 07-04-2017 11:38 AM
Plus 1 on the evapo rust. I just love the low knob Stanley’s.
View JBrow's profile
JBrow
1354 posts in 914 days
#12 posted 07-04-2017 04:08 PM
Marn64,
Paul Sellers’ video on restoring a bench plane might be worth a look…
https://www.youtube.com/watch?v=RYyV6IUpsYk
View bigJohninvegas's profile
bigJohninvegas
448 posts in 1456 days
#13 posted 07-04-2017 04:40 PM
Spot on with the evaporust, and a softer brush.
This old #5 Bailey plane looked just like yours before evaporust.
I still need a new tote for it.
the old cap iron and blade was to far gone so I bought a new one from lee valley.
http://www.leevalley.com/us/Wood/page.aspx?p=66868&cat=1,41182
I m a fan of evaporust. Just run it (less the wood) through the dishwasher, the soak in Evapo-Rust. Go easy on wire brushing. Try plastic brush, then brass, steel only as last resort.
-- John
Marn64
#14 posted 07-06-2017 08:12 PM
I went out and bought some evaporust today, I currently have the blade and chipbreaker soaking right now, I am going to check in on it in an hour.
View corelz125's profile
corelz125
389 posts in 970 days
#15 posted 07-07-2017 01:53 AM
The japanning is in pretty good shape for a plane that old that doesnt need much work
