Questions from an infill newbie
« back to Hand Tools forum
Forum topic by mmcc73 posted 07-03-2017 07:09 PM 1191 views 0 times favorited 7 replies Add to Favorites Watch
View mmcc73's profile
mmcc73
29 posts in 742 days
07-03-2017 07:09 PM
I acquired a couple of infill planes today. I’ve never owned much less used infills, and have a couple of basic questions.
So here they are (plus a panel marking gauge that I also got today – included because it is pretty)
http://imgur.com/a/mYiqk
I’m not seeing any marker’s marks on either one. The smoother is missing its iron, the shoulder plane is missing its wedge. Smoother is about 9” long, shoulder plan about 8” long and 1 3/8” wide.
On to the questions…
- Is it possible to determine who made these things?
- Are they particularly valuable? Assuming not I’d like to get them into usable condition.
- As you can see in the pictures, the tote on the smoother has come loose. Can I just epoxy it back in, or is there a more preferred method?
- Are there any sources for replacement irons for the smoother? I assume it would be used bevel up?
- For the shoulder plane, are there any patterns around for the wedge so I can make a replacement?
Thanks,
Clark
7 replies so far
View Don W's profile
Don W
18930 posts in 2682 days
#1 posted 07-10-2017 12:05 PM
Those are pretty nice. They do have some value, but using them wouldn’t hurt that value.
I’m going to guess these (and it’s just a guess) are Craftsman made. I haven’t seen any like the smoother before.
I’d want to see better pictures before I answered the epoxy question.
The smoother looks like a low angle(although it could be the picture) so it may be bevel down.
mmcc73
#2 posted 07-12-2017 07:39 PM
I’ll get some additional pictures of the smoother showing the knob and the bedding angle.
Would you think the shoulder plane is also craftsman made? It seems a little more refined than the smoothing plane.
Don W
#3 posted 07-12-2017 11:30 PM
It could be, but typically you’ll find a Makers mark on manufactured plane.
View Loren's profile
10477 posts in 3762 days
#4 posted 07-12-2017 11:43 PM
I’ll suggest the infill may have had the infill
replaced by a craftsman. The bed angle
is not shallow enough for a miter trimming
plane and quite shallow for a bevel-down
plane, so its intent is a quandary.
The shoulder plane is a common pattern
and I would guess factory made.
In terms of making a wedge, get a thin
stick of soft wood, cut the end to the rough
angle and stick it in the hole. The wood
will bruise where it jams and you can work
the angle on coarse sandpaper to figure
out what the exact taper you need to
make a wedge is.
mmcc73
#5 posted 07-13-2017 11:30 PM
make a wedge is.
- Loren
Great method – thanks!
mmcc73
#6 posted 07-13-2017 11:34 PM
Here are some more pictures of the smoother:
http://imgur.com/a/Ge1l2
The bedding angle seems to be 30 degrees. The angle of the infill seems to mesh up with the angle of the casting.
There are some pictures there of the knob as well. The main part of the knob seems to be made of rosewood, but there is some softwood tacked to the bottom – presumably a repair of some sort.
Does this help tell us what sort of plane this is?
#7 posted 07-13-2017 11:48 PM
With a bed angle of 30 degrees it’s in-between
the normal angles of bevel-up and bevel-down
planes. With the bevel up it becomes a high-angle
plane for difficult woods. The lowest angle
I can recall seeing a bevel-down plane would
be about 40 degrees.
