Router Kickback w/Bosch Ogee Bit
Forum topic by efsavage posted 889 days ago 967 views 0 times favorited 4 replies Add to Favorites Watch
View efsavage's profile
efsavage
26 posts in 1331 days
889 days ago
I was trying to use a brand new 3/4” ogee bit on the edge of a cribbage board, and was having terrible luck with the piece kicking back, even at a very low depth. After chunking a dozen test pieces at different speeds and heights I gave up. I ended up a smaller ogee, and making many passes, raising the bit about 1/8” each time.
My question is, is this typical with the more complex profile bits? I only have much experience with roundovers and chamfers which I’ve never had anything like this happen before. Is there something I could have done differently?
efsavage
#1 posted 889 days ago
To be clear, it wasn’t just the kickback that was a problem, it was held securely and with feather boards, I was more concerned with the massive tearout/chunks it was causing.
efsavage
#2 posted 889 days ago
You know, that’s probably exactly what I was doing. Looks like I should try climb-cutting on my next piece. Thanks!
View traupmann's profile
traupmann
122 posts in 959 days
#3 posted 889 days ago
If you have the control over the piece to climb cut, it will significantly reduce the splintering, The bit on a climb cut bites into the grain cutting it with a full cut. When conventionally cutting the material from the previous sweep doesn’t always clear causing some chance of entering the grain at an acute early angle and splintering; also the bit then has only a very small amount of wood to catch. This will split many types of wood. But CONTROL is the issue. Without control of the part being cut, you will have a safety hazard, so be careful out there.
-- chas -- looking for Serta sponsorship to go Pro...
View Brad_Nailor's profile
Brad_Nailor
2450 posts in 2129 days
#4 posted 889 days ago
Sounds like you might have been taking too large a bite too….1/8” is significant especially if you were routing against the grain
