Drawer Side Thickness
Forum topic by Redoak49 posted 07-02-2017 10:41 PM 1081 views 0 times favorited 16 replies Add to Favorites Watch
View Redoak49's profile
Redoak49
3394 posts in 2068 days
07-02-2017 10:41 PM
I am building a dresser 34” wide and 31” tall from Red Oak . The drawer boxes are about 29” wide, 17” deep and 6” tall and will be made from Ash with dovetail corners. The drawers will run on wooden runners with slick take.
The Ash stock is currently 3/4” thick and I think they look to heavy and considering reducing the thickness. What drawer material thickness do you think is best for this size drawer. The dresser is for my grand kids and i do want them sturdy.
16 replies so far
View Loren's profile
10477 posts in 3727 days
#1 posted 07-02-2017 10:49 PM
1/2” oak is plenty strong for almost any drawer,
imo, but there are aesthetic reasons for going
thicker in an heirloom piece.
It’s interesting to note that 3/4” was not a standard
dimension in furniture making prior to power tools.
I had a Stanley #46 skew dado plane for awhile and
the 3/4” cutter is conspicuously absent to modern
users. Stanley never made the cutter because the
dimension was simply not used.
Anyway, 5/8” looks nice. It’s unexpected in today’s
uniform furniture world of 1/4” steps in sheet-board
thickness. You can go a little thinner or a little thicker
for some added interest. I think James Krenov
discusses thickness in one of his books. I like to
mill and use 4/4 stock as thick as I can get it for
a given milling run on a project. I think 7/8” looks
sturdier than 3/4” and it adds a handmade aesthetic
to deviate from the norm.
View martyoc's profile
martyoc
44 posts in 996 days
#2 posted 07-02-2017 10:55 PM
I think that 1/2 inch is a good size for hardwood drawers. I’ve used that for quite a few dresser and table drawers over the years. It is sturdy and is also thick enough if you wish cut dados for drawer bottoms .
-- Marty O'C
View AlaskaGuy's profile
AlaskaGuy
4263 posts in 2388 days
#3 posted 07-02-2017 11:17 PM
1/2 for me. anything thicker looks to bulky to me. It’s personal taste if you asked me.
View jdmaher's profile
jdmaher
433 posts in 2659 days
#4 posted 07-02-2017 11:52 PM
I’m a 5/8” guy.
1/2” is probably plenty strong, but I do like the chunky feel of 5/8”
-- Jim Maher, Illinois
View Rich's profile
Rich
3328 posts in 668 days
#5 posted 07-03-2017 12:16 AM
I m a 5/8” guy.
- jdmaher
+1 on 5/8”. I think it looks best. No rationale, just what appeals to my eye.
View jonah's profile
jonah
1820 posts in 3378 days
#6 posted 07-03-2017 12:27 AM
1/2” is pretty standard, but deeper drawers could probably benefit from a little more stability. 5/8” isn’t bad, depending on the piece. For deeper drawers I would go 5/8” and for regular sized ones 1/2” is fine
Redoak49
#7 posted 07-03-2017 01:18 AM
Thanks for the comments….I agree that 5/8” sounds good and a reasonable compromise between strength and too chunky.
Time to get the planer out and make some chips.
View Aj2's profile
Aj2
1575 posts in 1877 days
#8 posted 07-03-2017 01:26 AM
I think somewhere between 1/2 and 5/8 is a good size.Also consider a center mount slide.When a drawer is wider then it is deep a center slide helps a lot.
-- Aj
View TarHeelz's profile
TarHeelz
62 posts in 2160 days
#9 posted 07-03-2017 01:37 AM
9/16!!!!. Everybody else is totally wrong!
-- Tar Heelz, Durham, NC USA
View GT350's profile
GT350
368 posts in 2061 days
#10 posted 07-03-2017 04:19 AM
5/8” is my favorite.
View pintodeluxe's profile
pintodeluxe
5732 posts in 2892 days
#11 posted 07-03-2017 04:19 AM
I think 5/8” looks more elegant than 3/4”, but feels every bit as strong.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2610 days
#12 posted 07-03-2017 06:18 AM
The drawers in my shop cabinets are approximately the same size, and made from 1/2” plywood. Plenty sturdy, and they carry a lot more weight than a dresser full of underwear and T-shirts ever would. And solid Ash is a lot stronger than plywood. So anything 1/2” thick or more would exceed your strength requirements by a large factor.
-- Mark Kornell, Kornell Wood Design
View Woodknack's profile (online now)
Woodknack
12211 posts in 2459 days
#13 posted 07-03-2017 07:24 AM
I just built a cabinet with 31” wide drawers, 1/2” material, no concerns at all about strength. Also have kitchen cabinets with drawers that wide, 1/2” material, loaded with pots and pans, no issues.
#14 posted 07-03-2017 07:36 AM
I think some of the arguments for 1/2” drawers
are a bit outmoded. For one, modern slides
mean the weight of the drawer isn’t as much of
an issue with smooth operation. It’s easy to observe
wear and sticky drawers in old chests with wooden
slides. Two, if you’re hand cutting dovetails, the
thinnest wood means the least amount of work
with a chisel.
AlaskaGuy
#15 posted 07-03-2017 05:57 PM
I’ve made a ton of drawers over the years, Kitchens get 1/2 BB ply and furniture get solid wood. Never a problem with and size drawer. I make a lot of wide drawer. Really wide drawer get rack and pinion drawer slides. It really is more about eye appeal that draw strength.
1/4 inch BB ply is stronger that you’d think.
