P15HH Powermatic Jointer
Forum topic by flatboarder posted 12-17-2010 03:54 AM 845 views 0 times favorited 2 replies Add to Favorites Watch
View flatboarder's profile
flatboarder
100 posts in 2849 days
12-17-2010 03:54 AM
Topic tags/keywords: plane
Is there a set torque amont for the inserts on the Byrd Shelix cutter heads. I was hoping that” just maybe”, just maybe”, someone would have worked this problem out by now ? It’s on the 15” powermatic planer. Thanks Chris
-- Ive cut this board three times and its still too short?
2 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3705 days
#1 posted 01-01-2011 04:23 PM
I assume you’ve checked out the Powermatic website, and read the manuals. I didn’t think they were torqued to a particular spec, just that they were tight ‘enough’, but then again I don’t have a large planer so I have no experience in this area. I know there is a LocTite product that would hold the bolts in so they don’t vibrate out, check out the Loc-Tite website for the different products they carry.
Happy New Year!
flatboarder
#2 posted 01-25-2011 01:35 AM
I found out from Byrd Tools that make the cutter head that it should be 45” ibs I did it and it worked like it never ever did before. Un believable.
