Using the full width of a Grizzly G0505
Forum topic by torea posted 07-02-2017 04:58 AM 561 views 0 times favorited 4 replies Add to Favorites Watch
View torea's profile
torea
24 posts in 894 days
07-02-2017 04:58 AM
Topic tags/keywords: grizzly g0505 planer cherry
I have a project coming up that requires 12.5” boards. I have some cherry that fits the bill, but it’s a tad cupped and the surface has a few chips. I want to run it through my planer to flatten and smooth it a little, but I’m worried that it’ll be too much for the machine, since the max width of a board for the G0505 is 12.5”.
Questions: Does anyone have experience planing boards the full width of this machine? Will it be ok if I just go slowly? Any advice for the best way to do this?
Thanks for the help!
View JoshNZ's profile
JoshNZ
105 posts in 1093 days
#1 posted 07-02-2017 05:15 AM
It should handle it fine so long as you take it in small passes. Starting with sharp blades will help too.
View knotscott's profile
knotscott
8056 posts in 3399 days
#2 posted 07-02-2017 11:52 AM
Clean the rollers too. Should be fine.
torea
#3 posted 07-03-2017 04:04 AM
Awesome, thank you!
runswithscissors
2764 posts in 2049 days
#4 posted 07-05-2017 04:03 AM
If you don’t joint it first, won’t it come out still cupped after you plane it? The rollers tend to flatten a plank while feeding it through the planer, then the cup reappears after it comes out the other side. (usually). You might try making a planing sled to overcome this.
