Equipment SAFETY tips: The Bandsaw
Forum topic by MsDebbieP posted 887 days ago 2305 views 3 times favorited 45 replies Add to Favorites Watch
18320 posts in 2329 days
887 days ago
Topic tags/keywords: safety bandsaw
Safety in the shop tips; for the bandsaw.
What are some tips to work safely on and around a bandsaw?
(See all SAFETY TIP GATEWAYS here)
45 replies so far
View ellen35's profile
ellen35
2441 posts in 1600 days
#1 posted 887 days ago
NEVER lose your concentration! In the quick of an eye, that nice slow machine that lulls you into thinking it is your friend and will never hurt you can give you a nasty cut… I have the scars to prove it!
View Jamie Speirs's profile
Jamie Speirs
3674 posts in 1024 days
#2 posted 887 days ago
Great Subject Debbie,
The safety instructions that come with the machines are generic not enough info.
Don’t ever force wood.
It can all of a sudden find a soft spot.
Never use a dull blade.
Like Ellen, I’ve the scars to prove it, lucky to still have 10 digits.
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
#3 posted 887 days ago
make sure to put that blade guard thingy down to the height of the wood .. (that’s a technical term, by the way)
View rance's profile
rance
3856 posts in 1328 days
#4 posted 887 days ago
Slow down when you get to the end of the cut so as to prevent the wood from lurching forward when it exits. Another technical term “Lurching”. :)
View Gregn's profile
Gregn
1643 posts in 1151 days
#5 posted 887 days ago
Lets not forget to unplug the band saw before changing the blade or belt speed.
View miserybob's profile
miserybob
88 posts in 1212 days
#6 posted 887 days ago
Reach around and PULL the wood through the last few inches – that way there’s no chance your digits will contact the front of the blade.
View Chip's profile
Chip
1904 posts in 2261 days
#7 posted 887 days ago
If you’re using a fence to make a straight cut, use a feather board to keep the piece tight up against the fence for best results. One less thing to concentrate on so you can keep your mind on the things everyone else has mentioned.
And when you can, use a push stick to save those finger tips from the “lurch” already brought up.
-- Better to say nothing and be thought the fool... then to speak and erase all doubt!
View docholladay's profile
docholladay
1258 posts in 1227 days
#8 posted 887 days ago
Be sure to use proper support for longer pieces as they come off of the saw. You need to focus on the cut, not supporting the weight of the workpiece. Also, use push sticks and feather boards to help in guiding the workpiece.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View mikethetermite's profile
mikethetermite
367 posts in 1434 days
#9 posted 886 days ago
Inform visitors that when they inter your shop if you are running the bandsaw (or any other machine). Not to speak, yell, or come near till the bandsaw stops.
Safety Glasses are a must
-- Mike The Termite ~~~~~ Working safely may get old, but so do those who practice it.
#10 posted 886 days ago
and to stand at the side
if the blade breaks be VERY careful opening the door as the blade may become a spring ready to attack. (One of our LumberJocks told of this experience)
View poopiekat's profile (online now)
poopiekat
2826 posts in 1902 days
#11 posted 886 days ago
Learning how to properly ‘fold’ a blade, into threesies, is a skill that is very necessary to learn, especially with 93” or longer blades. For storage, it’s better than hanging them from a nail high on the wall. There are you-Tube videos for this, though nobody does it exactly the way I was taught… and ‘unfolding’ them too is equally dangerous because of the energy stored in them that makes them want to spring out and scratch you right on the face! Here’s a video, but he neglects to mention that the teeth should be pointing away from you: http://www.youtube.com/watch?v=2WUiEJEZMTc&feature=related
View Donna Menke's profile
Donna Menke
487 posts in 2434 days
#12 posted 886 days ago
http://www.youtube.com/watch?v=TZvqtgTCtfM
This is a little safety video I made a year ago after watching the guy do the 3-D reindeer video. It upsets me to see people doing unsafe procedures with power tools, so I did my own video. People have responded that seeing my pore ol’ abused push stick was a good thing, and new to them.
I also have all 10 digits- and no scars from band saw use. I’ve gotten hurt from table saws, power sanders and drill presses- and scared a lot with routers and lathes. Never needing more than a band aid.
Safety is no accident-
Donna
-- "So much wood. . .so little time!" www.woodworks-by-donna.com
#13 posted 886 days ago
and that’s why your book is so good, Donna – you are a great teacher!
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1283 days
#14 posted 886 days ago
make sure al in alignment and with propper tension
bee sure all is tighten and asambled correct before the first run
take care
Dennis
Edit: use a zerocleance plate
Donna Menke
#15 posted 886 days ago
Aw thanks, Ms Debbie- I try my best.
showing 1 through 15 of 45 replies
