Wood ID & Finishing - Help Please!
Forum topic by Seeharlez posted 12-16-2010 02:41 AM 1097 views 0 times favorited 10 replies Add to Favorites Watch
View Seeharlez's profile
Seeharlez
83 posts in 2956 days
12-16-2010 02:41 AM
Hi All,
I bought an “assortment” of wood on craigslist and I’m not sure what type of wood this is. Can anyone help?
It is not very hard and not very dense. It planes super smooth, in fact it came out of the thicknesser like glass.
I tried oiling it and it went on a little blotchy. You can see this in the first picture with the knot hole in it.
In the 2nd and 3rd picture you can see how the color darkens in places. This is the natural appearance – no finish or shadows…maybe a bit of a shadow in the near the bottom of the board in the 3rd picture.
For reference, the board in the picture is about 6-7” wide.
Also if anyone has some suggestions on a simple finish for this type of wood that would be very helpful. I’m just using it to make some small boxes so the finish required is more for appearance then protection or durability.
Thanks!
Greg
-- Greg - Vancouver, BC
10 replies so far
117060 posts in 3540 days
#1 posted 12-16-2010 02:46 AM
Looks like pine Greg. That’s a tough one to finish unless you use some blotch control on it first.
This should help.
http://www.youtube.com/watch?v=IfCYMdrP8rM
View terrilynne's profile
terrilynne
836 posts in 2856 days
#2 posted 12-16-2010 02:52 AM
Does it smell like pine?
-- Terri, Rocky Mountain High Colorado!
View John Ormsby's profile
John Ormsby
1283 posts in 3700 days
#3 posted 12-16-2010 02:56 AM
Might be yellow cedar.
-- Oldworld, Fair Oaks, Ca
View Gregn's profile
Gregn
1642 posts in 2946 days
#4 posted 12-16-2010 03:18 AM
Might be pine, but it kinds looks like cedar. A smell check will give you a good clue. The cedar won’t be strong but will still have an oder to it. Either will need a wood conditioner.
Seeharlez
#5 posted 12-16-2010 03:22 AM
It doesn’t smell like anything! The texture does remind me a bit of Cedar but I only really know red cedar. It definitely does not smell like pine though. What other senses can I use…sight, smell, touch…only taste and sound left…
Good Video Jim – thanks!
Seeharlez
#6 posted 12-16-2010 06:03 AM
Well no definitive answer yet but I did find a cool website that is workth checking out. You can search hundreds of species of wood by name, characteristic or other criteria and it has a lot of info on each.
“http://www.thewoodexplorer.com/”
View Dan's profile
Dan
3630 posts in 2843 days
#7 posted 12-16-2010 06:50 AM
Cut into it. Is it hard or soft? try carving it with a knife or blade and see how easy it is to cut. That might help narrow it down a bit.
-- Dan - "Collector of Hand Planes"
John Ormsby
#8 posted 12-16-2010 07:15 AM
It is most likely Alaskan yellow cedar. It is normally very tight grain and silky smooth. You might call some local wood suppliers and see if they have some in stock.
It could also be a very light western red cedar.
I have both types of these cedars and you sample look like cedar.
It is hard to tell from just pictures.
Seeharlez
#9 posted 12-16-2010 07:09 PM
Would a simple wax work without blotching?
View Lee Barker's profile
Lee Barker
2170 posts in 2813 days
#10 posted 12-17-2010 06:09 AM
I think it’s hemlock. The color is right, the parallel grain is right, the blotching is typical, even that single dark line in the grain on the first left hand board. Yeah, I’m 99% hemlock. Here in Oregon the guys pounding nails call it ‘piss fir’ because it smells a little like urine when it’s cut green. Not repugnantly so, but vaguely.
I think you would minimize the blotching by using a surface coat—lacquer or wipe on poly. Try some of each on a piece and shoot us another image.
