Tapered leg jig for table saw
Forum topic by Andy Brownell posted 12-16-2010 02:38 AM 3990 views 1 time favorited 6 replies Add to Favorites Watch
View Andy Brownell's profile
Andy Brownell
144 posts in 3156 days
12-16-2010 02:38 AM
Anyone have any recommendations for a variable shop made leg taper jig for a table saw that I can make?
I have several different size tables that all require tapered legs.
-- Andy Brownell
View Chip's profile
Chip
1904 posts in 3997 days
#1 posted 12-16-2010 02:44 AM
Andy, if you enter “taper jig” into the search engine above, quite a few results appear that might give you some ideas.
-- Better to say nothing and be thought the fool... then to speak and erase all doubt!
View Gregn's profile
Gregn
1642 posts in 2888 days
#2 posted 12-16-2010 02:47 AM
Hinge 2 boards together at one end and a stop at the other with a bar and a bolt and a wing nut to adjust for different tapers.
View kenn's profile
kenn
810 posts in 3625 days
#3 posted 12-16-2010 03:27 AM
It’s also usful to have a bridge that rides over top of your table saw fence, and if you want 4 sided tapers you’ll need to add a dowel to the stop block that will hold your leg elevated and keep the taper consistent. Good luck.
-- Every cloud has a silver lining
View TheDane's profile
TheDane
5366 posts in 3568 days
#4 posted 12-16-2010 03:41 AM
Here’s one from Charles Neil … it is safer than the 2-boards-and-a-hinge jig, is pretty easy to make, and is (IMHO) a better solution: http://charlesneilwoodworking.com/references/taperjig.pdf
Charles has a YouTube video ( http://www.youtube.com/watch?v=pIc1m5s-jiE&feature=player_embedded ) that deals with taper jigs, etc … worth watching!
—Gerry
View PeteMoss's profile
PeteMoss
207 posts in 3375 days
#5 posted 12-16-2010 02:44 PM
I second Gerry’s suggestion. I made the Charles Neil jig and it works wonderfully.
-- "Never measure......cut as many times as necessary." - PeteMoss
View Knothead62's profile
Knothead62
2581 posts in 2866 days
#6 posted 12-16-2010 03:21 PM
Or you can buy one at Woodcraft stores. Fairly inexpensive.
