Can you make a tenon with a router?
Forum topic by Peter5 posted 12-14-2010 10:26 PM 7591 views 1 time favorited 19 replies Add to Favorites Watch
View Peter5's profile
Peter5
66 posts in 2712 days
12-14-2010 10:26 PM
I’ve been contemplating how to get my tenons better with large pieces of lumber. I can get them pretty crisp with smaller projects, but with large stock it’s quite difficult to get the lumber to stay in place with the miter gauge. I was thinking of trying to make the tenon with a rabbit bit on a router, by just setting the proper depth and routing away a rabbit all around to reveal the tenon. It seems like this would give me much more control, not having to push a big piece of lumber through a saw. The only downside I can think of is that I could only make the tenon as long as the rabbit, but my 3/8 inch rabbit is fine for most of the jobs I have in mind. Am I failing to think of something here, or is this worth a try?
-- Pete, Long Beach, CA http://www.petedeeblefurniture.com
19 replies so far
View Camper's profile
Camper
232 posts in 2764 days
#1 posted 12-14-2010 10:37 PM
Hey Peter, I am sort of in the same boat as i need to make tenons on an approximately 4’x2’ table top for breadboard ends. I have seen/read people use a router to do these with a regular straight bit and a guide. I do not see why a router would not work. What I am concerned with is the removal of stock between the tenons. Hopefully someone with more experience will chime in.
-- Tampa-FL
View dbhost's profile
dbhost
5686 posts in 3140 days
#2 posted 12-14-2010 10:42 PM
I bet you could come up with some sort of jig to guide it, kind of like a router planing jig… I am sure it’s doable, but how hard do you want to work at it?
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
Peter5
#3 posted 12-14-2010 10:42 PM
Hi Camper, thanks for your thoughts. I’m not concerned about removing stock between tenons because these are hidden (not through) so I’m just making one big tenon and one big mortise. I think I’m going to just try it out today- I’ll report back.
View brunob's profile
brunob
2277 posts in 4078 days
#4 posted 12-14-2010 10:43 PM
Here’s a site to find a jig: tenon jig
-- Bruce from Central New York...now, if you'll pardon me, I have some sawdust to make.
Peter5
#5 posted 12-14-2010 10:43 PM
dbhost, I was planning to use a rabbit bit with a bearing, so no jig necessary- I think.
Camper
#6 posted 12-14-2010 10:47 PM
Peter, I am no expert but I think one of the things frequently pointed out regarding larger pieces of wood is wood movement due to change in humidity etc. I am not sure a single tenon (I am assuming glued) would accommodate this….I have seen in several places multiple tenons where the center one is glued and the other ones are not glued….again I hope someone with more experience can chime in…
-- Tampa-FL
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3493 days
#7 posted 12-14-2010 10:52 PM
Why not if your unsure of this make mortices on both ends and fit floating tenons. They are much easier to make .Make this so you have two mortices (holes ) and one longer tenon (rod) to fit between both they glue up great a dry fit being the best way so that all fitting is spot on before gluing best of luck with your project look up floating tenons on the web browser,Alistair
View TheDane's profile
TheDane
5367 posts in 3571 days
#8 posted 12-14-2010 10:57 PM
Pete—Check this out … http://woodgears.ca/pantorouter/index.html
—Gerry
View live4ever's profile
live4ever
983 posts in 2918 days
#9 posted 12-14-2010 11:04 PM
You could put together a horizontal slot mortiser…a fairly easy project if you have some ply and mdf laying around. The hardware requirements are minimal.
View rance's profile
rance
4256 posts in 3069 days
#10 posted 12-14-2010 11:15 PM
Your choice:
1) Long straight bit on router & use tennoning jig
2) Horizontal Router ( http://woodgears.ca/slot_mortiser/index.html )
3) Pantorouter ( http://woodgears.ca/pantorouter ) (new)
View AaronK's profile
AaronK
1505 posts in 3372 days
#11 posted 12-14-2010 11:39 PM
pat warner had a jig that did this – it looked like the popular designs for a loose tenon jig, but used a piloted rabbet bit to go around the end of the stock to shape the tenon. I think with a collet extension you could easily make longer tenons.
alternatively, you could always mill them out using a plunge router with the workpiece fixed and moving the router over multiple pieces for stability and accuracy.
View tbone's profile
tbone
275 posts in 3593 days
#12 posted 12-14-2010 11:43 PM
Here’s a good explanation of what I think you are asking. I did a breadboard end for my dining table and have been pleased with the results.
http://www.eaglelakewoodworking.com/category/Fine-Woodworking.aspx
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
AaronK
#13 posted 12-14-2010 11:46 PM
View richgreer's profile
richgreer
4541 posts in 2983 days
#14 posted 12-15-2010 01:02 AM
Usually you cut the mortise first and you fine tune the size of the tenon to fit. A router with a rabbet bit will not let you easily vary the size of the tenon.
If your willing to spend some money, here is the perfect solution
http://www.rockler.com/product.cfm?page=22431&filter=leigh
To be totally “up front” I considered this option but did not buy it. Instead I went with this option, which uses loose tenons, and I am very happy with it.
http://www.mortisepal.com/
View thebigvise's profile
thebigvise
191 posts in 2809 days
#15 posted 12-15-2010 01:17 AM
I made a walnut bed and chose to make mortises in the posts and tenons at the ends of the (8” by 7’ by 1 1/2”) side rails. I used a hand-held router with a straight bit and a fence. I agree with richgreer that the mortises should be cut first, then the tenons. I left the tenons about 1/32 oversized, then hand-sanded down to a snug fit.
-- Paul, Clinton, NC
