Problems with my DeWalt planer- please help!
Forum topic by Peter5 posted 12-14-2010 10:19 PM 6176 views 0 times favorited 8 replies Add to Favorites Watch
View Peter5's profile
Peter5
66 posts in 2826 days
12-14-2010 10:19 PM
I bought a DeWalt planer second hand and it seemed to work great at first but eventually started overheating. I checked the blades and realized they were dull, so I put brand new blades on. It worked OK for a while before shutting down completely (wouldn’t start up). I noticed that the brushes were blown out, so I ordered new ones and put them in. With the new brushes it started right up, I took about 6 passes on a piece of rosewood and it died again. I pulled out the brushes and, just from those 6 passes, the brushes were completely blown out again. Am I doing something wrong? What could cause brand new brushes to blow out so quickly? Also, it was making sparks (the sparks were actually flying out as I was using it)- does that help explain anything? Lastly, is it worthwhile to take it to a DeWalt service center and have them repair it, or would it be better to just buy a new one? Thanks in advance for your advice.
-- Pete, Long Beach, CA http://www.petedeeblefurniture.com
8 replies so far
View TheDane's profile
TheDane
5441 posts in 3686 days
#1 posted 12-14-2010 11:01 PM
Pete—I don’t think it is you or anything you are doing wrong. Sounds like you have a bad motor.
Which model is this (DW733, DW734, or DW735)? If it is a 733, it might not be worth repairing.
Have you contacted DeWalt about the problem?
—Gerry
View rance's profile
rance
4258 posts in 3183 days
#2 posted 12-14-2010 11:12 PM
Your motor armature is eating the brushes. Most likely needs to be replaced, as opposed to repaired.
Peter5
#3 posted 12-15-2010 07:28 AM
Thanks guys. I’m going to look into getting a new motor armature- is that something I can replace myself?
View GFYS's profile
GFYS
711 posts in 3494 days
#4 posted 12-15-2010 07:54 AM
inspect the commutator …the multi-sectioned part the brushes ride upon.
rance
#5 posted 12-20-2010 11:00 PM
Dan is right. Here’s a picture :
See the blackened ring? That’s what’s most likely eating your brushes.
If you have a lathe(yes, even a wood lathe), you could possibly mount the armature on your lathe(commutator to the left for more rigidity). Then VERY CAREFULLY, scrape away the burned part of the commutator till you are down to smooth Brass(or Copper). Then a delicate swipe with 120 grit or so(very lightly here). This may get you back in bidness.
BE WEWEY CAREFUL TO NOT BREAK THE WIRES CONNECTED TO THE COMMUTATOR ELEMENTS. Also, don’t try this if you are not proficient with turning.
As for replacing the armature yourself, if you’ve ever taken a motor apart(that has brushes) and successfully reassembled it, then you’d probably do ok.
TopamaxSurvivor
18285 posts in 3699 days
#6 posted 12-21-2010 09:13 AM
use emery cloth, not sandpaper on electrical parts.
Peter5
#7 posted 12-22-2010 08:41 AM
Thanks everyone, when things slow down in my shop I’ll try to get the commutator on my lathe and see how it goes. I really appreciate the input.
View GrenenstalNL's profile
GrenenstalNL
1 post in 986 days
#8 posted 10-07-2015 08:46 AM
Goodday,
I’m curious if Peter5 ever got round to getting the commutator from the housing. We ran into the same problem here in Holland, with a DW733 that lost a chip of the brushes. We are trying to remove the commutator from it’s housing but we can’t find a decent way to remove the pulley from the commutator’s axle. Removing the pulley is neccessary if one wants to be able to remove the commutator from the housing. The free end of the commutator is not readily suitable for applying great pressure. Nor is there any free axle space for clamping on the pulleyside.
I have been able to find out the pulley is left threaded, the parts list of dewalt mentions this.
It there anyone here who has managed to do so? And if so: what’s the trick?
EDIT: In the meantime my father has managed to remove the pulley. The pointer of the thread being LH and, despite my feelings about applying pressure to the gear on the other side of the commutator, putting the other end in the vise with the use of aluminum plates, has helped him enough to solve the problem.
