Solid walnut desktop question.
Forum topic by Damage Inc. posted 06-28-2017 04:46 PM 517 views 0 times favorited 5 replies Add to Favorites Watch
View Damage Inc.'s profile
Damage Inc.
41 posts in 2893 days
06-28-2017 04:46 PM
Topic tags/keywords: walnut
Hi all. Been a while since I’ve been around. Life has allowed me to get back to making scrap and sawdust finally. I’m making a solid walnut desk that will be supported by three walls. I’ve got the lumber milled down to 3.5”w x 1.5ish” this pieces. My furniture maker neighbor is helping me with this part as he has the big industrial sized equipment. When gluing the pieces together I know all about alternating the grain and all that, but I disagree with how he recommends I glue the pieces together.
My though was to dowel or biscuit them together. He says that’s a waste and just glue should do the trick. Any help you guys could give would be great.
Thank you.
5 replies so far
View KelleyCrafts's profile
KelleyCrafts
2869 posts in 763 days
#1 posted 06-28-2017 04:57 PM
Just glue will do the trick just fine. Dowels or biscuits help with alignment, I don’t really ever use them.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
Damage Inc.
#2 posted 06-28-2017 05:10 PM
I get it. Furniture building neighbor guy also say in the same breath that he’s had to replace a few of his recent tabletops because they split…....
View JayT's profile
JayT
5673 posts in 2235 days
#3 posted 06-28-2017 05:31 PM
Glue is stronger than wood, so a good clean joint on long grain will be stronger than anything else you can do to it.
If his tabletops are splitting, it’s more likely from either the wood not being completely dry, the pieces not mating well at the joint or from not allowing for seasonal wood movement in the design, not from whether or not he uses dowels.
View AlaskaGuy's profile
AlaskaGuy
4205 posts in 2333 days
#4 posted 06-28-2017 05:49 PM
Long grain to long grain gluing need nothing but well fitting jointed edges. The joint comes together with out having to use clamp pressure to close gaps. In my opinion forget the alternating the the growth rings. Just lay you boards out to get the best grain and color match. You what your table to look good, right?
Who is doing the glue up? You or him?
Check out this video.
https://youtu.be/H5fXUzIF0MU
View Woodknack's profile
Woodknack
11774 posts in 2404 days
#5 posted 06-28-2017 05:52 PM
about alternating the grain and all that, but I disagree with how he recommends I glue the pieces together. .
Thank you.
- Damage Inc.
Just glue.
Alternating grain is a myth, won’t hurt you but won’t prevent cupping either.
