Building a finish over another finish
Forum topic by Dchip posted 12-14-2010 05:12 PM 930 views 0 times favorited 1 reply Add to Favorites Watch
View Dchip's profile
Dchip
271 posts in 3217 days
12-14-2010 05:12 PM
Topic tags/keywords: question finishing
I have some figured box tops that I’m finishing. I did a coat of sanding sealer, sanded it back, then 3 coats of wiping poly so far. I decided I want to try to build a finish on one so I can then polish it to a mirror finish.
My question:
Is there any way I can build a finish with either lacquer or shellac over the poly without jeopardizing the adhesion, or do I need to sand it back? I’ve tried to rub out poly in the past, but even after waiting a couple of weeks for it to fully cure, I was less than satisfied with the results
Thanks.
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
1 reply so far
View cabs4less's profile
cabs4less
235 posts in 2727 days
#1 posted 12-15-2010 07:38 AM
I’ve always heard shellac will stick to any thing i would scuff the surface and build my finish up with shellac then rub it out but i would let the shellac cure for a week or two to be safe
-- As Best I Can
