How to clean?
Forum topic by christhetalentedone posted 12-14-2010 06:27 AM 1677 views 0 times favorited 20 replies Add to Favorites Watch
View christhetalentedone's profile
christhetalentedone
30 posts in 3756 days
12-14-2010 06:27 AM
we all know what it is like to have pitch and resin on the blades, but what happens when the inners of a saw is coated in it? most of the castings at least have a few areas of build up, i dont think i have enough blade/bit cleaner for that and $ is a little short at the moment. sooooooo i was wondering if anyone had any tips,advice,ideas or just random crap to throw in.
either way it would be appreciated
Thanks
-- the talented one
20 replies so far
13641 posts in 3579 days
#1 posted 12-14-2010 06:32 AM
SIMPLE GREEN
spray and let sit
spray and scrub
View ksSlim's profile
ksSlim
1290 posts in 3127 days
#2 posted 12-14-2010 06:39 AM
Another vote for SIMPLE GREEN, it works in my shop for blades, router bits and other grubby parts.
-- Sawdust and shavings are therapeutic
View Gregn's profile
Gregn
1642 posts in 3221 days
#3 posted 12-14-2010 03:43 PM
I agree with using Simple Green as well and when working with high resin type woods as Yellow Pine I like to clean this area often as part of my weekly and daily maintenance routine. I even use it on other machines that I use for Yellow Pine.
View Dan's profile
Dan
3630 posts in 3118 days
#4 posted 12-14-2010 06:45 PM
Make that 4 for Simple Green! I use it for all my blades, tools, kitchen counters, bathroom floors, ext ext..
-- Dan - "Collector of Hand Planes"
View FirehouseWoodworking's profile
726 posts in 3511 days
#5 posted 12-14-2010 06:46 PM
Absolutely Simple Green. Even better if you can lay the saw over on its side/back/front/other side so that you get to let the Simple Green soak in rather than running off.
I get mine in the automotive section of WalMart.
Good luck! Cheers!
-- Dave; Lansing, Kansas
View childress's profile
childress
841 posts in 3779 days
#6 posted 12-14-2010 06:51 PM
While simple green does work good, you could also use windex, or any window cleaner with ammonia.
-- Childress Woodworks
View NBeener's profile
NBeener
4816 posts in 3412 days
#7 posted 12-14-2010 06:53 PM
FYI: the Simple Green folks caution against letting Simple Green sit on aluminum for more than 10 minutes.
Just something to keep track of…..
Generally, though, I love the stuff. Use it, 50/50 with water, in my parts washer. Does a great job on my bicycle parts !
-- -- Neil
christhetalentedone
#8 posted 12-15-2010 07:57 AM
and now for the second question, i did that then after i pulled the metal out to clean it they rusted right away, what is the best way to phase from water to oil with ought having rust? because now i have to clean it more, which i can do with oil and steel wool but that is even more annoying than what i just had to do. so im hoping someone has a miracle up there sleeve ~crossing fingers~
-- the talented one
View dfdye's profile
dfdye
372 posts in 3275 days
#9 posted 12-15-2010 10:57 AM
I use simple green as a pitch remover, and it works just great.
As for rust prevention, I have never heard complaints about WD40 as a drying treatment after cleaning. I would spray it on and wipe the tools down to get the water away from the surface. After that, 3 in 1 works for me as a normal “wipe down” oil before storage. I know others love camellia oil, but I never have bothered to switch from 3 in 1. I guess when I run out of this can I may consider it. . . .
-- David from Indiana --
View Knothead62's profile
Knothead62
2600 posts in 3199 days
#10 posted 12-15-2010 03:21 PM
dfdye, do you wipe off the WD-40 or oil before using the tools to keep from contaminating the wood? I was working in the shop this week and pondering the same question. Thanks, LJers!
View MedicKen's profile
MedicKen
1615 posts in 3700 days
#11 posted 12-15-2010 03:52 PM
Easy-off oven cleaner
childress
#12 posted 12-15-2010 07:48 PM
”but what happens when the inners of a saw is coated in it? most of the castings at least have a few areas of build up”
”i did that then after i pulled the metal out to clean it they rusted right away”
I’m not 100% sure, but it sounds like you removed the coating put on by the mfg. to prevent rust and corrosion…
christhetalentedone
#13 posted 12-15-2010 09:38 PM
it appeared on the machined faces, and i thought about using wd40 but i do believe it has silicon in it.
-- the talented one
NBeener
#14 posted 12-15-2010 10:20 PM
I don’t think WD40 DOES have silicone in it.
http://www.wd40.com/faqs/
It’s a good go-to for many shop lube tasks, along with white lithium grease !
-- -- Neil
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3344 days
#15 posted 12-15-2010 11:41 PM
WD-40 in the spray can has paint thinner as well. I’m not sure of the ratio. I still have a quarter drum of the unmixed stuff out back.
I prefer Scheaffer’s Penetro 90 myself. It is the best that I have found for rust removal, preventative and lubricant. Made in the USA in St. Louis by the same family since 1839. Fantastic stuff!
