Finishing Eastern Red Cedar
Forum topic by Fax posted 06-27-2017 05:32 PM 1306 views 0 times favorited 34 replies Add to Favorites Watch
View Fax's profile
Fax
62 posts in 690 days
06-27-2017 05:32 PM
Hello friends,
Trying to refinish a cabinet that I think it is Eastern Red Cedar.
Very old cabinet from Germany, made over 50 years ago.
It looked gray without any beauty or grain.
It had been waxed all these years and the wax got so hard
Now the wood graing is SO BEAUTIFUL,
Sanding dust is reddish.
Very hard wood.
Very heavy compared to any other wood I have worked on.
Very dense and britle.
Beautiful grain patterns.
Reddish and White when I apply Lacquer thinner to wipe off the wood.
I would like to apply Waterlox Varnish or Arm R Seal
Question
Should I apply Seal coat of shellac,
because it had so much wax over the years, even if I rinse it thoroughly with Acetone and Lacquer Thinner,
Then Waterlox or Arm R Seal
I did some reading about Eastern Red Cedar and someone mentioned that this wood, eastern cedar has oils and must apply seal coat of shellac, otherwise the varnish will not dry.
What do you recommend?
Thank you very much for your help !
Julian
-- Julian Paul Jones
34 replies so far
View CharlesNeil's profile
CharlesNeil
2468 posts in 4104 days
#1 posted 06-27-2017 05:43 PM
got a picture .. is the wood soft and does it smel llike cedar
View Fax's profile
Fax
#2 posted 06-27-2017 05:49 PM
- CharlesNeil
It is very hard, feels like a rock .
Very heavy.
Edges are very hard.
Had a gray look before I sanded it.
As soon as I wet it a bit with solvent lacquer it shoes beautiful color, reddish and white.
I will try to smell it as soon as I get home from work.
I used lots of lacquer thinner and acetone to wipe old grime, waxes, and oils that were used.
CharlesNeil
#3 posted 06-27-2017 05:53 PM
That doesnt sound like cedar, cedar is soft , usually some what knotty ..
View johnstoneb's profile
johnstoneb
3070 posts in 2406 days
#4 posted 06-27-2017 05:59 PM
Need a picture. If it is actually from Germany I doubt that it is Eastern Red Cedar. Eastern red cedar is just a little bit softer than Cherry. Cedar 900 Janka, Cherry 950 Janka. Eastern Red Cedar is a juniper it doesn’t have much or any oil some of the knots may bleed. You might want to seal them with shellac but if it is actually 50 years old any sap will have dried up long ago.
It is not particularly heavy about the same weight as Black Cherry a little bit lighter than Black Walnut
As Charles says pictures would really help. If you sand down to new wood the cedar small will fill your shop. You’ll smell it as soon as you walk into the shop. You haven’t mentioned any smell and you would notice that immediately.Hence the name aromatic red cedar.
-- Bruce, Boise, ID
View Fax's profile
Fax
#5 posted 06-27-2017 06:02 PM
- CharlesNeil
As a classical guitar player I know that whenever I see a new guitar, I try to smell it inside because of the beautiful cedar scent.
But this doesn’t have that obvious scent of cedat.
And it is impossible to put a nail in it; must dril first.
Thank you very much for your help!
Julian
View Fax's profile
Fax
#6 posted 06-27-2017 06:04 PM
Need a picture. If it is actually from Germany I doubt that it is Eastern Red Cedar. Eastern red cedar is just a little bit softer than Cherry. Cedar 900 Janka, Cherry 950 Janka. Eastern Red Cedar is a juniper it doesn t have much or any oil some of the knots may bleed. You might want to seal them with shellac but if it is actually 50 years old any sap will have dried up long ago.
- johnstoneb
Now that I think of how much sanding I did yesterday, I didn’t notice any scent of cedar as I do when I see a new guitar made with cedar; you feel it right away.
Julian
View Fax's profile
Fax
#7 posted 06-27-2017 06:10 PM
I will post pictures how it looks when i wet it with acetone
View Fax's profile
Fax
#8 posted 06-27-2017 08:33 PM
- CharlesNeil
View Fax's profile
Fax
#9 posted 06-27-2017 08:38 PM
CharlesNeil
#10 posted 06-27-2017 08:44 PM
not sure, but its definately not
Cedar
View Fax's profile
Fax
#11 posted 06-27-2017 09:40 PM
Cedar
- CharlesNeil
Since I sanded and rinsed the wood several times with lacquer thinner to remove all wax,
I would like to go with the Waterlox varnish.
Would you recommend a seal coat of Shellac or not needed anymore ?
View ArtMann's profile
ArtMann
1215 posts in 1050 days
#12 posted 06-27-2017 10:42 PM
Eastern Red Cedar is as common as weeds around here. I have cut down several in my yard and I wish the rest of them were gone. It is a little bit oily but I never heard of anybody having to seal with shellac prior to varnishing if it has been dried well. It is a popular wood for building bird houses because it is rot resistant. I just ground up a stump in my yard that had been there since I cut the tree down 30 years ago. The only use I have for it is to CNC carve outdoor signs for campers and rustic cabins. I have not found it to be very heavy or very dense. Are you sure we are talking about the same species?
View Fax's profile
Fax
#13 posted 06-27-2017 11:34 PM
- ArtMann
I don’t know the woods well. I am just learning it each day after work. My wife calls it my “Mid-life crisis” but I think it is the nicest hobby weather married or not married. I am amazed how much there is to know to make wonderful finishes. Even my kids find reasons to hang around me more.
Now my wife is actually very happy that I kept at it for a couple of years now; she has a big list of TO DO for me. Kitchen cabinets, dining table, chairs, bedroom set, bookcases, food trays, kitchen wood stuff, and anything that has wood … My son damaged some furniture and I was not upset at all…more reasons to justify my “Mid-life crisis”
johnstoneb
#14 posted 06-28-2017 12:37 AM
Definitely not cedar can’t help beyond that.
-- Bruce, Boise, ID
View Fax's profile
Fax
#15 posted 06-28-2017 12:41 AM
Definitely not cedar can t help beyond that.
- johnstoneb
Actually now that I think of it, I don’t smell cedar after so much sanding.
showing 1 through 15 of 34 replies
