PLANER Metabo DH330
Forum topic by majuvla posted 888 days ago 1402 views 0 times favorited 5 replies Add to Favorites Watch
View majuvla's profile
majuvla
1576 posts in 1033 days
888 days ago
Hello woodworkers,
I would appreciate any suggestion about this planner,if there is anybody with expiriance of using this planer.
Maybe to compare to Makita 2012NB.
I know that DW 733,734,735 are better, but I’m hobby woodworker so I don’t have so many rough woods to work.
Thanks in advance for all advices.
Best regards
Ivan
-- Ivan, Croatia, Wooddicted
5 replies so far
majuvla
#1 posted 887 days ago
Can any body explain ’’SNIPE’’ problem with portable ticknessers ? since I don’t understand this slang word.In translation it is some bird.
Thanks
12048 posts in 1507 days
#2 posted 887 days ago
ivan
i haven’t used any of the makes you mention
so i didn’t respond
to me they are basically all the same
(maybe copy’s of each other) ?
snipe is the thinner ends that can happen
when a board enters and exits the tool
and only one roller is holding it
3 ways to help with that
1 – run a ‘sacrifice’ board first
and butt your work to or next to it (the ends)
then use ‘sacrifice’ board last too
2 – make your boards longer and cut off the ends
after the planer
(if they will be tenons i leave them alone
as they will get made thinner anyway)
3 – lift the work as you put it into the planer
and lift it as it comes out of the planer
(not a guaranty but it helps)
i always run all the boards together
one behind the other
(or the ends just next to each other)
when you pull them out
be sure to orient them all the same
so you don’t do the same face again
(if you turn one over
turn them all over ,
or turn the whole pile over together)
hope this helps
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1281 days
#3 posted 887 days ago
ivan I don“t know the excact model but Metabo has general a good reputation
in europe among both hobbyworkers and proff. and there combi jointer/planer is used in lot
of schools in Denmark
hope this help you a little
Dennis
Beginningwoodworker
13225 posts in 1839 days
#4 posted 887 days ago
I think the Dewalt or Makita planer is good. Dont know much about the Metabo.
-- CJIII Future cabinetmaker
majuvla
#5 posted 887 days ago
Thanks Patron for detailed explanation.The second solution is the most acceptable for me (1. and 3. later when I get some more expiriance with this tool).
Thanks all.
