Spray can problems
Forum topic by rayn posted 06-26-2017 02:58 PM 663 views 0 times favorited 10 replies Add to Favorites Watch
View rayn's profile
rayn
175 posts in 3338 days
06-26-2017 02:58 PM
Topic tags/keywords: question
I often have a problem with spray can finishes. I shake well and when I spray (colors) it sometimes comes out almost like fine sand or granular clumps. These are new cans at normal room temperature. I tried to contact rustoleum but did not receive an answer
Ray
-- Ray,Iowa
10 replies so far
View Rich's profile
Rich
3547 posts in 709 days
#1 posted 06-26-2017 03:53 PM
I’ve never experienced that. It’s not one of their textured products, is it? I’m sure you’d know if it was, but I had to ask :)
Was it just one can, or did several behave that way?
View moke's profile
moke
1229 posts in 2896 days
#2 posted 06-26-2017 04:45 PM
Ray,
Are you using that new Rustoluem spray top can? If so…throw it away and get the old can…..I have had terrible luck with it.
Mike
-- Mike
View EyeUrnMayDen's profile
EyeUrnMayDen
5 posts in 457 days
#3 posted 06-26-2017 04:54 PM
one trick i learned from spraying nitro on guitars, is keep your cans in a bath of hot water. it will increase pressure (and keep it more consistent) as well as improve atomization.
That said i have had problems with rustoleum cans as of late (new spray top and regular ones) and usually go with duplicolor instead. They have nice fan nozzles and do a lot of automotive paint, so good UV inhibitors, good durability and some pretty cool colors.
View Rich's profile
Rich
#4 posted 06-26-2017 05:46 PM
Ray,
Mike
- moke
That’s a good point. If you have some spray cans that spray well, maybe you could try using the spray head from one of them on your Rust-Oleum can to see if it helps.
View jbay's profile
jbay
2601 posts in 1019 days
#5 posted 06-26-2017 05:50 PM
I heard you’re supposed to shake them until the steel ball quits rattling…. :)
View rayn's profile
rayn
#6 posted 06-27-2017 12:29 AM
Thanks for all your suggestions
Ray
-- Ray,Iowa
View Woodknack's profile
Woodknack
12338 posts in 2500 days
#7 posted 06-27-2017 12:45 AM
I heard you re supposed to shake them until the steel ball quits rattling…. :)
- jbay
LOL
View ocean's profile
ocean
102 posts in 953 days
#8 posted 06-27-2017 12:54 AM
Glad to hear someone else is having a problem with Rust Oleum spray paint also. Came out looking look very fine sand was in the paint. I took the paint back and the guy at the counter had no answer. I asked if the shipment had come on a freezer truck, I know that can produce the same effect on spray cans, but he did not know. Tried a different brand and had no problem.
-- Bob, FL Keys
View dhazelton's profile
dhazelton
2789 posts in 2416 days
#9 posted 06-27-2017 01:01 AM
Different problem bit I’ve bought PB Blaster recently and multiple cans seem to have no propellant. Maybe the gov’ment is changing the rules on the manufacturers and propellant’s are not what as ozone depleting (and actually working) as they once were.
woodbutcherbynight
5545 posts in 2529 days
#10 posted 06-27-2017 03:09 AM
Rustoleum’s newer spray nozzles clog with paint after 1st use. After that most spew and spit or throw terrible spray patters. This has been my fix, immediately after use use brake cleaner and shoot through the nozzle till it comes clear, the use compressed air to clean out the cleaner and let dry.
