fence system for Grizzly table saw
Forum topic by seturner posted 06-25-2017 07:29 PM 1871 views 0 times favorited 31 replies Add to Favorites Watch
View seturner's profile
seturner
29 posts in 505 days
06-25-2017 07:29 PM
Hello,
I just purchased a used Grizzly G1023RLX table saw that did not come with the rails or fence.
What would you recommend for a fence system? I do not need the 50” capacity that the saw came with(I have a track saw).
Thanks
31 replies so far
View Loren's profile
10477 posts in 3734 days
#1 posted 06-25-2017 09:04 PM
Incra and Vega are popular aftermarket fences.
Incra won’t save you much space in the shop tho.
The simplest thing is to cut-off your fence or
trade it to somebody for a shorter Biesemeyer
fence.
View Madmark2's profile
Madmark2
381 posts in 674 days
#2 posted 06-25-2017 09:07 PM
Incra 32”
M
seturner
#3 posted 06-25-2017 09:14 PM
I have a nice Delta Platinum Contractor saw with Unifence. Does anybody know if that fence and rails will bolt on?
Or would I be better off just selling the old saw and buying a new fence.
seturner
#4 posted 06-25-2017 09:15 PM
Is that the TS-LS or a different one? How hard was it to mount to your Grizzly?
Incra 32”
M
- Madmark2
Madmark2
#5 posted 06-25-2017 09:21 PM
It’s an LS. Incra LS-III fence mounts easily on any saw with two mounting holes on the front & back. They have universal mounts.
The Incra will bump your saw & skills to the next level – trust me.
M
View MrUnix's profile
MrUnix
6848 posts in 2285 days
#6 posted 06-25-2017 09:27 PM
~$200 for a Delta T3 (Biesemeyer) fence and rails at the BORG. You just missed out on a sale where they were around $180 or so.
#7 posted 06-25-2017 09:47 PM
I would switch the fences, personally. The
Unifence is a great fence.
View Gaffneylumber's profile
Gaffneylumber
102 posts in 914 days
#8 posted 06-25-2017 09:47 PM
I’ve got the T3 like Brad mentioned. It has been a great fence. It locks straight and slides smooth. You might have to modify it to fit (drill a couple of holes) but it wouldn’t take much. With that being said, I’ve always heard great things about the unifences.
-- Grayson - South Carolina
MrUnix
#9 posted 06-25-2017 09:50 PM
+100 – but they are hard to find. Sure wish Delta would start making them again.
Madmark2
#10 posted 06-26-2017 03:58 AM
Incra’s are different than most fences. Once zero’d they will always lock at the nearest 1/32” (or .5mm) +-0.002” every time! no double checking, no banging, no ginching, no more sneaking up on a dim. This will push you and your saw to the next level even on a Crapsman 113. series. Their miter gauges are top notch and deadly accurate for all crosscuts.
They’re worth every cent.
M
View AlaskaGuy's profile
AlaskaGuy
4274 posts in 2395 days
#11 posted 06-26-2017 06:21 AM
- MrUnix
And I’ll raise your +100 to +200
View knotscott's profile
knotscott
8103 posts in 3461 days
#12 posted 06-26-2017 10:51 AM
Grizzly sells the Shop Fox Classic, which is the stock fence on the G1023RL, and RLX. It;s a good Biese copy type fence, and will be a direct bolt on.
The Vega, Saw Stop T-GLide, Jet Xacat II, PM Accufence, HTC, and Incra are all good fences too.
The Unifence is a great fence too. If you can’t get a decent resale price for your Delta and Unifence, I’d definitely consider putting it on the Grizzly.
seturner
#13 posted 06-26-2017 02:25 PM
How does that work with the router table? I plan on putting my Benchdog cast router table on the right, since I can’t put it on the left of my Left tilt saw due to the motor.
Incra 32”
M
- Madmark2
Madmark2
#14 posted 06-26-2017 02:31 PM
The router shares the Incra LS-III fence with the saw. Same accuracy every time. I’ve got a 3-1/2hp Milwaukee router hiding under the plate.
M
seturner
#15 posted 06-26-2017 02:46 PM
Thanks Mark.
I would like to stand where your fence is, rather than to the side, though I am sure there is no problem doing that with the proper equipment.
The router shares the Incra LS-III fence with the saw. Same accuracy every time. I ve got a 3-1/2hp Milwaukee router hiding under the plate.
M
- Madmark2
showing 1 through 15 of 31 replies
