Planer roller resurfacing?
Forum topic by eflanders posted 06-25-2017 01:22 PM 534 views 0 times favorited 2 replies Add to Favorites Watch
View eflanders's profile
eflanders
301 posts in 1878 days
06-25-2017 01:22 PM
Topic tags/keywords: planer roller cover feed issue milling question resource
My old 13” Rockwell 13” planer is having issues feeding stock through it. I’ve gone through it completely, readjusted to spec all settings and have newly sharpened blades. The feed issue varies a little but it appears to me that after much observation, the out feed roller, which is smooth is the hang-up as feeding stock to that point is very consistent now. Based on this, I am wondering if theither out feed roller should get a rubber cover of some sort? This unit was used in a tech school for many years. Is it possible that the out feed roller down pressure is maybe too strong? Making it even stronger did not help. If covering/coating the roller is a good idea, where in the USA is this done? What would it cost? Any guidance and suggestions are welcome. Thanks in advance!
2 replies so far
View JackDuren's profile
JackDuren
388 posts in 987 days
#1 posted 06-25-2017 01:28 PM
are you sure it’s the roller or the bracket is cracked underneath?
View Ger21's profile
Ger21
1075 posts in 3159 days
#2 posted 06-25-2017 01:30 PM
