Face frame overlap/width of stiles
Forum topic by one60fourth posted 06-24-2017 01:53 PM 498 views 0 times favorited 3 replies Add to Favorites Watch
View one60fourth's profile
31 posts in 1522 days
06-24-2017 01:53 PM
Is there any reason I shouldn’t select a stile width (1 3/4) that provides only 1/4 inch overlap into a drawer opening? I’m using under mounted drawer slides so I don’t need much space on the sides. I have a bank of drawers adjacent to a frame and panel door (2 1/4 wide frames) separated by a stile. A 1 3/4 stile next to a 2 1/4 door frame looks good visually. But it gives me only 1/4 inch overlap on the drawer side (3/4 inch on the door side). Any problem with this?
3 replies so far
View Loren's profile
10081 posts in 3578 days
#1 posted 06-24-2017 04:40 PM
Probably not but I would mock up a stile
using the hinge you’re going to use to
make sure the door doesn’t bang into the
drawer front when opened all the way.
#2 posted 06-24-2017 06:03 PM
That part should be OK. I’m using Blum 110 degree full inset door hinges so it won’t come close to the drawers when opened. Thanks for the reply Loren.
View jerryminer's profile
904 posts in 1372 days
#3 posted 06-24-2017 09:33 PM
I don’t know why you’re concerned about “only” a 1/4” overlap into a drawer opening.
I usually keep the FF flush to a drawer opening—makes drawer slide installation easier, and the 1/4” is wasted space—can be better used in the open area behind the door—but it’s a small amount. No big deal.
