rip blade for ripping plywood?
Forum topic by Beginningwoodworker posted 12-12-2010 01:18 AM 5966 views 0 times favorited 16 replies Add to Favorites Watch
Beginningwoodworker
13345 posts in 3636 days
12-12-2010 01:18 AM
I have Freud LU87R010 10” thin kerf 24 tooth rip blade, I am wondering could I use my ripping blade for ripping plywood? or should use my 80 tooth Freud Avanti TK806 thin kerf blade for ripping plywood? That I have on my miter saw.
16 replies so far
13600 posts in 3304 days
#1 posted 12-12-2010 01:27 AM
a combination saw should do fine
rip teeth are like little chisels
for plowing out solid wood
croscuts are like little axes
chopping across the grain
combination blades
are both mostly
so can do either
Beginningwoodworker
#2 posted 12-12-2010 01:31 AM
I had a combination blade on my unisaw but it bogs it down.
View Kevin's profile
Kevin
462 posts in 3168 days
#3 posted 12-12-2010 01:31 AM
I’ve used a good combination blade for cutting 3/4 plywood with no problems for quite a long time. I’m pretty sure I always put the good side facing up on the table saw to prevent the most tear out Someone correct me if i’m wrong on that, but for a circular saw you have the good side down.
-- Williamsburg, KY
Kevin
#4 posted 12-12-2010 01:33 AM
How many HP is your unisaw? I have a grizzly 1023 3hp and with a 50t full kerf cutting 1” oak doesn’t bog it down at all.
-- Williamsburg, KY
Beginningwoodworker
#5 posted 12-12-2010 02:31 AM
My Unisaw is a 1-1/2hp
Beginningwoodworker
#6 posted 12-12-2010 02:31 AM
Kevin, I am talking 5/4 to 8/4 stock.
View 8iowa's profile
8iowa
1580 posts in 3724 days
#7 posted 12-12-2010 03:01 AM
Your rip blade is designed for solid woods, and will do a great job in this instance. I would not use it for plywood.
I have the Avanti TK806, and frankly, I don’t know if there is a better blade for cutting plywood. The plywood we purchase today has veneers as thin as 10 thousandths of an inch – I’ve measured. The TK806 cuts 3/4” plywood with virtually no tear out, much smoother in fact than the factory cut edges.
I just contacted Freud this week and was informed that the TK 806 is no longer available. They did recommend their LU74R010 or the Diablo D1080X. Both are 80T HiATB blades with a 5 degree hook, which is virtually identical to the TK806.
My 50T combination blade causes too much tear out on plywood. I have a 60T Freud crosscut blade with a 10 degree hook that does a decent job on plywood, but not nearly as good as the TK806.
Kevin
#8 posted 12-12-2010 03:27 AM
Beginningwoodworker, that makes more sense now. I mostly work in 4/4 solid wood and 3/4 plywood so i’m not sure how i’d go about it. 8Iowa seems to have nailed the plywood non-tearout :)
Kevin
-- Williamsburg, KY
View Bob Kollman's profile
Bob Kollman
1798 posts in 3154 days
#9 posted 12-12-2010 05:13 AM
My freud combo 40 tooth blade sharp cuts plywood okay to good,
dull it’s barley acceptable to maybe okay. Do with what you have
until you can afford what’s better!!! I don’t have an 80 tooth for
ply wood, but I am sure they are worth the investment.
-- Bob Kenosha Wi.
View knotscott's profile (online now)
knotscott
7980 posts in 3339 days
#10 posted 12-12-2010 06:27 AM
I’d definitely use your TK806 since you’ve got it. It’s got more teeth than your rip blade, plus it has an ATB grind that’ll slice better. If you find that the 80T bogs too much, you might try something like a Forrest WWI or Infinity 010-060…both Hi-ATB 60T blades, which is the cleanest cutting grind for plywood. You could also try a Freud LU79R006 60T Hi-ATB 7” blade for ~ $50….your saw should have a pretty easy time spinning that one.
View traupmann's profile
traupmann
124 posts in 2750 days
#11 posted 12-12-2010 07:23 AM
Ripping and crosscutting are about lumber. Plywood is both no matter the direction. I have found that I cut 1/4 oversize on first cut, then I get a much better cut on size. Keep the teeth low and if the bottom is important, tape it.
-- chas -- looking for Serta sponsorship to go Pro...
View docholladay's profile
docholladay
1287 posts in 3022 days
#12 posted 12-12-2010 08:30 AM
My favorite blade that stays in my table saw 95% of the time is a 40 tooth Freud General Purpose blade. I have also used a 50 tooth combination blade. They both work very well for cutting plywood, both rip and crosscut. Remember, when cutting plywood, regardless of whether it is a rip or crosscut, you are still both ripping and crosscutting at the same time because the layers of the plywood alternate directions. A good sharp combination blade is the best way to go.
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
knotscott
#13 posted 12-12-2010 11:28 AM
”A good sharp combination blade is the best way to go.”
A good sharp combination blade certainly doesn’t give the least tearout or the most efficient cut. I guess the “best way to go” depends on your objectives.
View ChrisForthofer's profile
ChrisForthofer
150 posts in 3030 days
#14 posted 12-12-2010 01:46 PM
Get one of the new Freud Fusion Premier 40T blades. Works amazing on Ply and man made materials as well as hardwoods. Little to no tearout on top or bottom with a Zero clearance insert and a finish that easily equals my Freud glue line rip in hardwood. As far as a do everything blade goes in my experience the Fusion is as close as it gets.
Chris.
-- -Director of slipshod craftsmanship and attention deficit woodworking
8iowa
#15 posted 12-12-2010 03:24 PM
Perhaps some of you will enjoy Nick Engler’s technical discussion of sawblade design features;
http://www.shopsmithacademy.com/SS_Archives/SS109/SS109_Choosing_Saw_Blades.htm
