Quick question about dust collection
Forum topic by Paul C. posted 12-12-2010 12:58 AM 924 views 0 times favorited 5 replies Add to Favorites Watch
View Paul C.'s profile
Paul C.
154 posts in 3240 days
12-12-2010 12:58 AM
I have a quick question. I have a single stage 800 cfm dust collector, hooked into a cyclone. It removes chips from my jointer, planer and table saw very well through a 4” pvc duct. I collect dust from the other side of my shop through a 4” pipe that runs over my 8’ ceiling. It is reduced down to 2.5 inches for a maximum of 2 foot runs, using reducing tees. It seems pretty good, but am I being delusional?
5 replies so far
View mfike's profile
mfike
100 posts in 3661 days
#1 posted 12-12-2010 01:01 AM
I’m not real sure what your asking Paul. If it removes the chips and more importantly removes the fine dust then it’s doing good. So I guess your not delusional?
Paul C.
#2 posted 12-12-2010 01:16 AM
I guess my point is, I don’t know what good dust collection looks like, So I don’t really know how well it really is working. I know I am being cryptic, but I can’t seem to “find my voice” today.
13603 posts in 3336 days
#3 posted 12-12-2010 01:17 AM
i have a 6” main
i went to 4” for the separate tools
and went down to 2 1/2” for that orange hose they have
to try and get corners and crannies
no luck
seems you can force air
but you can’t suck it the same
the shop vac’s are higher velocity
(why they make so much noise)
and are made for smaller hoses
i guess that’s why they have one 4” hose
with a handle to sweep the floor
Paul C.
#4 posted 12-12-2010 01:53 AM
it is 10 feet from my DC to my jointer, and 15 feet to my router table on the other end of the ceiling run. I will try to get pictures of my tiny little shop.
I hope this helps.
All the runs are smooth ABS
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3707 days
#5 posted 12-13-2010 12:07 AM
Is the dust being collected? Is the DC screaming? If there is no dust left over and your DC isn’t complaining about the change in diameter, I would go with the flow (pardon the pun) and accept that the DC is doing its job. If dust is not being collected (or if its sitting in the elbows or straight runs) or the DC is screaming like it is starving for airflow I would re-engineer your system. I agree with Charlie that 800 cfm sounds a bit low volume for such long runs.
