How do you cut a circle in half.
Forum topic by wseand posted 06-23-2017 08:46 PM 1120 views 0 times favorited 22 replies Add to Favorites Watch
View wseand's profile
wseand
2796 posts in 3247 days
06-23-2017 08:46 PM
Topic tags/keywords: question circles
Ok here we go. I need to cut a large fan shroud as close to in half as I can. Making two projects out of it, a entertainment center and wine rack. The shroud is 50” ID and 58” OD, it has an arc to it that is about 8” in depth. I have a few ideas but looking for any ideas. Some reason I just can’t get it into my pea brain of how to do this. Sent pic to help.
Any ideas would be great.
Thanks,
Bill.
22 replies so far
Smitty_Cabinetshop
15706 posts in 2824 days
#1 posted 06-23-2017 08:52 PM
Grab a stick, any kind of long straight edge, scrap, whatever, and place one end on the inside edge of the rim. Stand up the straight edge and slide it back and forth along the upper edge of the rim, looking for the longest run that registers. When you find it, hold it steady and mark the location of the straight edge on the rim, top and bottom. That’s half.
Unless I really don’t understand what you’re trying to do, that’s how I’d proceed.
View DS's profile
DS
3033 posts in 2626 days
#2 posted 06-23-2017 08:53 PM
Bill, it seems that your work piece is already marked at the quadrant points with holes drilled for brackets.
Lay this flat on your work bench, use a small square from the bench and eyeball and mark a line through the holes.
Then pick your tool of choice – maybe a hacksaw, or a grinding disc and don’t stray too far from the lines.
Good Luck
19462 posts in 2062 days
#3 posted 06-23-2017 08:55 PM
Measure the circumference. Divide it by two. You can use just a piece of string or such.
View waho6o9's profile
waho6o9
8525 posts in 2782 days
#4 posted 06-23-2017 08:56 PM
It seems to me there’s 4 holes on the top ( 2 where the L brackets are still attached to ) and those
should be 4 quarters, so the reference points would be at 12 and 6 o’clock .
Scribe a line and jigsaw it with a metal blade. Or put a metal cutting blade on a skill saw and have
at it.
View GR8HUNTER's profile
GR8HUNTER
5168 posts in 918 days
#5 posted 06-23-2017 08:57 PM
take the 50inches so take 50×3.14 ”= 157 divide that into 2 = 78.5so just mark anywhere measure around it 78 1/2 inches will be half :<))
https://images.search.yahoo.com/search/images;_ylt=AwrBT8wPf01ZerUAsxJXNyoA;_ylu=X3oDMTByMjB0aG5zBGNvbG8DYmYxBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=diameter+of+a+circle&fr=yfp-t-s
View Loren's profile
10477 posts in 3853 days
#6 posted 06-23-2017 09:03 PM
I would stretch a piece of string around the top
rim and mark it with a sharpie to indicate the
end. String does stretch a bit. Stretch it out
on the ground and mark the center. Then
put it back around the rim and mark those
two points with chalk or tape or a scratch.
That marks the one rim. To accurately mark the
larger rim, put it flat on concrete surface and
drop a plumb line from each mark on the inside
and mark the concrete. Put the string under
carefully and stretch it between the two marks
from under the larger rim. You’ll need a helper.
When both marks are bisected by the string,
mark where the string exits the larger rim.
Then do your best to connect the two marks
on each rim.
I think this is a pretty exact and sort of pita way
of doing it, but if you really want it as close
as possible to evenly divided, I think it’s a
good bet.
All that said, you can easily tape a piece of string
to any point on the rim and stretch it across
and eyeball it. The longest spanning point
is the exact bisection and I think you’ll actually
be surprised at how accurate your eye is.
View papadan's profile
papadan
3584 posts in 3574 days
#7 posted 06-23-2017 09:10 PM
”How do you cut a circle in half. ” With a circumference, silly boy! ;-)
View jbay's profile
jbay
2898 posts in 1105 days
#8 posted 06-23-2017 09:17 PM
For entertainment value….
Dunk it down 25” (29” if you use the big side) in the swimming pool and mark the wet line…..
papadan
#9 posted 06-23-2017 09:21 PM
I like this one!
- jbay
wseand
#10 posted 06-23-2017 09:31 PM
- jbay
Jbay will this pool work. Only one I have.
wseand
#11 posted 06-23-2017 09:45 PM
Gentlemen. Thanks for ideas. I’ve been remolding a friends house lately and just didn’t have enough brain cells for this.
Papadan,
Do they sell circumference at Harbor Freight?
Loren,
I was thinking of something along those lines. I just didn’t know how to find that center mark. Great idea with the sting and plumb Bob.
View jbay's profile
jbay
#12 posted 06-23-2017 09:48 PM
You could cut a piece of wood 29” (or 25” depending on the side you want to mark)
stand them both against a wall and mark both sides along the top of the wood
View MrUnix's profile
MrUnix
7053 posts in 2405 days
#13 posted 06-23-2017 09:50 PM
Easiest method has already been described a couple of times. And it’s even easier if you just use a tape measure instead of a string or piece of wood. Pick a point, any point, and measure from there to the other side. Wherever the longest measurement is obtained is dead center. Circles have magic properties :)
View jbay's profile
jbay
#14 posted 06-23-2017 10:48 PM
- MrUnix
No method is realized until at least 8 people say the same thing. :)
View BenDupre's profile
BenDupre
684 posts in 694 days
#15 posted 06-23-2017 11:26 PM
Use an angle grinder
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
