Cutting MDF/laminate
Forum topic by Knothead62 posted 12-11-2010 09:15 PM 1056 views 0 times favorited 5 replies Add to Favorites Watch
View Knothead62's profile
Knothead62
2584 posts in 2956 days
12-11-2010 09:15 PM
Topic tags/keywords: question tip tablesaw
I have a piece of countertop that I want to use for an art center for my grandson. I will have to trim a bit off for the top shelf. CT is about 12 in. deep; need 8 in. for the shelf. It is not real long so I can use the tablesaw. My question is what to cut it with. I have the following blades for the TS:
Dewalt 10” 60 Teeth ATB Construction Series
Dewalt 10” 32 Teeth ATB Construction Series
Generic (came with saw) 10” 28 Teeth Combination
Thanks in advance for your help.
5 replies so far
View Gregn's profile
Gregn
1642 posts in 2978 days
#1 posted 12-11-2010 09:40 PM
I would use the 60 tooth and use masking tape on the cut line before cutting to help prevent chip out.
View mfike's profile
mfike
100 posts in 3661 days
#2 posted 12-12-2010 01:04 AM
What Greg said.
View Kevin's profile
Kevin
462 posts in 3200 days
#3 posted 12-12-2010 01:35 AM
X3!
-- Williamsburg, KY
Knothead62
#4 posted 12-12-2010 11:22 PM
Thanks! I can see the wisdom in your answers. I failed to mention (senior moment) that the piece of laminate has a bullnose edge so I will have to cut it with the laminate down on the TS top. Any further suggestions for protecting the top? Maybe a sacrificial piece of plywood, still using your instructions? The length of the piece will be 22-1/2 inches. Thanks!
Knothead62
#5 posted 12-14-2010 10:22 PM
Thanks for the replies. Hopefully, I can get some pictures to post later.
